| Hello I am super new to electronics, but have an idea to connect 10 musicians accross a large space through a ten channel mixer scheme. The longest distance between musician and mixing desk (which would have to be unmanned - automated - would be 1 mile) so I am wondering whether there would be an issue with delay? I have been assured by a sound guy I know that it all depends on the cable... Either way, I would appreciated if someone could point me in the right direction to find a simple but concise circuit diagram showing microphone input and sound output for each of the 10 musicians... Any suggestions? All appreciated Last edited by badger; 24th September 2008 at 08:34 PM. | |
| First off, if you want a mixer, BUY ONE - you can buy high quality mixers at very little cost, far less than the components (or even the knobs) would cost you. Time delay over a mile isn't a concern, but losses in the cable is - not a trivial thing to overcome, particularly if you want decent quality. Next - 'automated mixer' - no such thing. What on earth are you trying to do?. | |
| I am trying to get a group of musicians to play together - but at different points in a piece of music. For example - (call musicians 1 - 10 ) Musician 1 (channel 1)starts playing Musician 2 (channel 2) wants to play along to musician 1 - so he turns on to channel 1 and plays along to his music. Musician 3 tunes into channel 2 and hears musicians 1 & 2 and hears them playing, and joins in...and so on. Would this work, or am I being totally unrealistic? And would there be sever feedback issues, or is there a system that would support this? Also, I am trying to create it so that is could be done through a computer that wouldnt have to be manned - this would ideally be a long term project... If the answer is yes to the first question (would this work) would you be able to tell me where I can get a circuit diagram to use to explain the project more clearly to collaborators? | |
| In large studios and broadcast situations one system that is used is Audio over Ethernet. Good if you want an off-the-shelf solution. Check out http://en.wikipedia.org/wiki/Audio_over_Ethernet Torben
__________________ Curiosity was framed. Ignorance killed the cat. | |
| Thankyou - I will check it out now. | |
| Hi Nigel! I know you are very knowledgeable in the audio field so I'm writing this to learn more about what you mean by the above. In my experience, automated mixers are quite common. Most of the ones I know of can be automated using simple onboard programs and/or by MIDI control messages from onboard or outboard MIDI sequencers or controllers. Some other mixers can be set to automatically control gain--for instance, to assist in live mixing so that the engineer doesn't need to be constantly chasing faders all over the board. Given that, I suspect you were talking about the automation of some other aspect of the mixer. Can you clarify that for me if you get a chance? Thanks! Torben
| | (permalink) | |||
An example would be for mixing down to master a CD, at a particular point in the song you might need to add an effect, or alter the gain on one particular track for a time, by storing these changes you can make the mixing down semi-automated. Also, if you were doing live PA for a big tour, you might store basic settings for each song, modify them doing the sound check at each venue, then select that setting for each song, and manually tweak from there. Or you might just write it down on a sheet of paper, and do it all manually The last thing you want on a live gig is unreliability, or the mixer doing something strange on it's own. Quote:
Has the OP even considered the cost of more than a mile of cable?. | ||||
| | (permalink) | ||||||||
What I consider to be semi-automated would be more along the lines of what my 01V offers, without the benefit of outboard control from a sequencer or production software: 99 scenes which may be recalled at defined times, but without the near-infinite control I can get by controlling it from Cubase or similar (or a MIDI sequencer). Quote:
But again the definition for these things is somewhat different--normally they are just to automatically mute and unmute (sometimes smoothly) audio inputs according to their signal levels. I wouldn't expect anybody to think that they are a kind of magic box you can plug your band into and have it come out sounding good. This reminds me of a gig we played in Tuscon AZ. I may have been the first drummer in that sound guy's history to ask him to "please take the gate off the kick drum". The turkey wasn't using his ears; he was hoping that some default settings on a piece of gear could do his job for him. So my softer kicks wouldn't come through, but if I hit it even a little harder, suddenly it was just BOOM BOOM BOOM. That little anecdote is just to point out that in essence I agree with you--there is no hardware (or software) available which will replace a good sound tech's ears and experience (as the saying goes: "ears and years"). Quote:
Anyway, thanks for the clarification. I guess I have to disagree with you on the meaning of "automated mixer" though, since the meaning of "automated mixer" isn't (AFAIK) generally taken to mean "magic sound engineer in a box" but "mixer which can replay a recorded set of instructions". I agree that "automatic mixers" are not quite what they might sound like, but then I don't know that Joe Q. Public really thinks much about the difference between "automatic" and "automated". Torben
__________________ Curiosity was framed. Ignorance killed the cat. | |||||||||
Torben
It might be cheap and nasty, but it works perfectly - only used it about twice, never had a gig to do with a drummer since I also bought a bass drum mike, which although it was shown in stock actually wasn't - and didn't arrive until after the last gig with a drummer, so it's never been used yet. I hate drummers! It's no coincidence that there's very little difference between 'drummer' and 'dumber' Apologies if you're a drummer, as I think you mentioned earlier?. | ||
| | (permalink) | ||||
. . . A: Drool. Quote:
Torben
The only one she's not gigged at is drumming. | ||
| LED running light circuit diagram and Clock cicuit diagram | fernnie | Electronic Projects Design/Ideas/Reviews | 1 | 18th November 2008 03:05 AM |
| Need to find AT89S52 Programmer schematic diagram... | chunei | Micro Controllers | 6 | 21st August 2007 09:44 AM |
| 8- channel mixer. | markian80@yahoo.com | Electronic Projects Design/Ideas/Reviews | 1 | 6th November 2006 05:16 PM |
| newbie, where to find servo controller circuit diagram ? | calico | General Electronics Chat | 5 | 18th February 2006 02:20 PM |
| Trying to find a PCB design program - advice please | HandyMan | Electronic Projects Design/Ideas/Reviews | 9 | 21st February 2005 05:22 PM |
