here some samples ASM code of 8051(89C51) ...try load this programe and test ur microcontroller circuit ...make sure ur microcontroller circuit is working properly...i confirm that this code is working.best of luck! i recomanded that to use LCD from OPTREX company.... ---------------------example1---------------------------------- ;Check busy flag before sending data, command to LCD ;P1=data pin ;P2.0 connected to RS pin ;P2.1 connected to R/W pin ;P2.2 connected to E pin ORG MOV A,#38H ;init. LCD 2 lines,5x7 matrix ACALL COMMAND ;issue command MOV A,#0EH ;LCD on, cursor on ACALL COMMAND ;issue command MOV A,#01H ;clear LCD command ACALL COMMAND ;issue command MOV A,#06H ;shift cursor right ACALL COMMAND ;issue command MOV A,#86H ;cursor: line 1, pos. 6 ACALL COMMAND ;command subroutine MOV A,#'N' ;display letter N ACALL DATA_DISPLAY MOV A,#'O' ;display letter O ACALL DATA_DISPLAY HERE: SJMP HERE ;STAY HERE COMMAND: ACALL READY ;is LCD ready? MOV P1,A ;issue command code CLR P2.0 ;RS=0 for command CLR P2.1 ;R/W=0 to write to LCD SETB P2.2 ;E=1 for H-to-L pulse CLR P2.2 ;E=0 ,latch in RET DATA_DISPLAY: ACALL READY ;is LCD ready? MOV P1,A ;issue data SETB P2.0 ;RS=1 for data CLR P2.1 ;R/W=0 to write to LCD SETB P2.2 ;E=1 for H-to-L pulse CLR P2.2 ;E=0, latch in RET READY: SETB P1.7 ;make P1.7 input port CLR P2.0 ;RS=0 access command reg SETB P2.1 ;R/W=1 read command reg ;read command reg and check busy flag BACK:CLR P2.2 ;E=1 for H-to-L pulse SETB P2.2 ;E=0 H-to-L pulse JB P1.7,BACK ;stay until busy flag=0 RET END ------------------------example2------------------------------ ;calls a time delay before sending next data/command ; P1.0-P1.7 are connected to LCD data pins D0-D7 ; P2.0 is connected to RS pin of LCD ; P2.1 is connected to R/W pin of LCD ; P2.2 is connected to E pin of LCD ORG MOV A,#38H ;init. LCD 2 lines,5x7 matrix ACALL COMNWRT ;call command subroutine ACALL DELAY ;give LCD some time MOV A,#0EH ;display on, cursor on ACALL COMNWRT ;call command subroutine ACALL DELAY ;give LCD some time MOV A,#01 ;clear LCD ACALL COMNWRT ;call command subroutine ACALL DELAY ;give LCD some time MOV A,#06H ;shift cursor right ACALL COMNWRT ;call command subroutine ACALL DELAY ;give LCD some time MOV A,#84H ;cursor at line 1,pos. 4 ACALL COMNWRT ;call command subroutine ACALL DELAY ;give LCD some time MOV A,#'N' ;display letter N ACALL DATAWRT ;call display subroutine ACALL DELAY ;give LCD some time MOV A,#'O' ;display letter O ACALL DATAWRT ;call display subroutine AGAIN: SJMP AGAIN ;stay here COMNWRT: ;send command to LCD MOV P1,A ;copy reg A to port1 CLR P2.0 ;RS=0 for command CLR P2.1 ;R/W=0 for write SETB P2.2 ;E=1 for high pulse CLR P2.2 ;E=0 for H-to-L pulse RET DATAWRT: ;write data to LCD MOV P1,A ;copy reg A to port1 SETB P2.0 ;RS=1 for data CLR P2.1 ;R/W=0 for write SETB P2.2 ;E=1 for high pulse CLR P2.2 ;E=0 for H-to-L pulse RET DELAY: MOV R3,#50 ;50 or higher for fast CPUs HERE2: MOV R4,#255 ;R4=255 HERE: DJNZ R4,HERE ;stay until R4 becomes 0 DJNZ R3,HERE2 RET END
__________________ --Turn arround, Smell What You Dont See--- | |
