| Notices |
| | (permalink (permalink)) |
| i am going to build a project for my school and decided to do a gps project. I will want to create a gps receiver, and have it display to an lcd just like any normal gps receiver with a color display. I also wanted to set up a heads up display to integrate it all together, so i am making a heads up navigational display. This is a senior project that i have to do to get my degree at devry university. Any ideas or suggestions would be greatly appreciated. My goal is have a a integrated system using gps, probably a 5in lcd screen to view the map, and a projector to display the identical map on the lcd screen to the windshield as a heads up display. Can anyone give me any help on this idea? Thanks. | |
| This seems very ambitious for a senior project. I think the receiver is the easy part. The difficult part will be handling mapping on the LCD. It would be much easier to perform the mapping on a laptop for instance. Implementing a trip computer, however, should be straightforward. | |
| The navigation system built into cars does in fact use a computer (and many use DVDs to store the map data). It is not going to look like a traditional desktop PC, but will be an embedded machine, probably with an integrated controller for the LCD and DVD drive as well as an interface for a touchscreen or pushbuttons. My portable GPS uses a strong ARM processor and I would guess the systems in cars probably use a more powerful and faster CPU since power consumption is less of an issue. | |
| how would you suggest i go about doing this? Probably using a single board microcontroller to hook up a gps engine and, how would i use an lcd with it as well? I understand this is an extensive project, i just need to be led in the right direction. Thanks. | |
| I would like to thank you for the help you have given me so far. Its starting to seem more and more difficult the more i think about it but i will not become discouraged. It seems to me that you have done a similar experiment, or have done something of this nature. I would like to have some more information about how this all works, because i feel a little bit lost. If you could explain to me about how the integrated controller on the lcd works for a gps, it might help me a lot. For the lcd, i can't seem to find a graphic lcd with an integrated controller like you said i needed, maybe its because i dont understand what it quite is, sorry to ask but i need more direction. | |
| Ok, I *still* think that the graphic LCD will be very difficult to do given that this is a student project -- I am guessing the time line is limited. Some graphic LCDs will allow you to address each pixel individually. For instance, you say "set pixel 100,12" to graylevel 3 or something like that. On other displays, you must redraw the entire screen. Clearly, the first type is easier to work with because it contains a framebuffer memory and the logic to address/control the display. The second type has a memory, but you reload the entire memory when you want to make a change to the display. So you must have your own framebuffer and/or recompute the image anytime you want to make a change. I would get started on this project as soon as possible, because you will spend a TON of time writing the software. | |
| i see, so basically the only way to do this is by writing each pixel in one at a time, according to where you move. If that is the case, i would probably have to shy away from something like this, because it would take me months just writing a program for it. The timeframe i have for this project is about 8 months, i would probably have better success using an the gps engine and integrating it to a pda or such, and writing a program to have the pda connect to heads up display? What would you suggest? It needs to be extensive enough to take about 8 months of planning and building, let me know what you think. | |
| Your original project described something very similar to my personal GPS receiver which is an etrex legend. I would suspect garmin spent a couple of man years just writing the software for the device. And yes, I think that project is quite complex. What you probably could do would be to forget about the graphic display and instead use a text display and some memory. You could build a simple system that would incorporate a trip computer (velocity, speed, etc) as well as a memory to record waypoints. Even backtracking to the waypoints would not be terribly difficult if you just print out the direction in terms of degrees rather than actually drawing a compass. | |
| i would make it a text display, but there isnt much unique about that in which the heads up display would be something very similar to the ones in gm cars already. i would probably would want to use an ique, that has gps, hook it up serially to a projector to be used as a headsup display, cahnge some settings on the ique, or something of that nature. Does that sound like something possible? The project just needs to implement hardware and software together. | |
