Old 14th September 2008, 12:19 AM   #1
Default led timer
Hello everyone,
I'm starting a project and I don't quite know where to start. I've browsed through this forum a bit but could not find my exact situation... Anyways I need in my car an led that turns on for 6 seconds. It has to come on when the key is in the on position, stays on for 6 seconds, turns off and stays off until I turn the key back on. I think the 555 timer might work but I know nothing about that chip. Any help would really be appreciated.
Thank you.
salutka is offline
Old 14th September 2008, 03:48 AM   #2
a monostable 555 timer will probably do the trick in your case.
check this link out: ht tp://ww w.eleinm ec.c om/article.asp?4
(i can't post urls, so remove the spaces)
for an on time of about 6 seconds, you can use a 470uF capacitor and a 12Kohm resistor.
Riff Raff is offline
Old 14th September 2008, 05:01 AM   #3
Thanks for the info!
I drew up the circuit for final revision but I do have some questions, If the trigger pin is wired directly to the 0v, will the 555 timer run its cycle the moment it gets power? Also I assume that the output will be the same voltage as the VS?
Hope it's good.
salutka is offline
Old 14th September 2008, 05:33 AM   #4
Hi salutka,
you don't need to use a big electrolytic cap for the circuit. Reduce the capacity to 10µF and use a resistor of 570KΩ instead of 12KΩ.
The exact resistance value 546.1KΩi s achieved best by using a combination of a fixed value resistor (470KΩ) and a trimmable resistor of 100KΩ.
570KΩ will result in a time out of 6.262seconds. For an electrolytic I suggest to use a tantalum type capacitor.
Don't forget to smoothen the alternator voltage. (Not included in the schematic)
Boncuk
P.S. There is a small error in the schematic. The total resistance value has to be 546.1K.
Boncuk is online now
Old 14th September 2008, 05:53 AM   #5
So the IN with the 6.8k resistor and the TP1 have to be connected to the 12v?
And is your mistake the leg #1 of your variable resistor?
salutka is offline
Old 14th September 2008, 05:59 AM   #6
Sorry, the resistor is fine, forget what I said about the #1 leg!
salutka is offline
Old 14th September 2008, 09:58 AM   #7
TP1 goes to the positive battery terminal and IN goes to the key switch.
Old 14th September 2008, 03:02 PM   #8
Originally Posted by Boncuk View Post
Hi salutka,
Boncuk
570kΩ is not a standard value, the nearest standard value to 546.1k is 549k which is a 1% tolerance resistor.
In practise, there's no point in using such a precise resistor value because the 10µF capacitor will be 10% at best so use a 560k resistor.
if I know the answer.
Hero999 is offline
Old 14th September 2008, 10:42 PM   #9
Ah I see so every time the trigger gets a signal it restarts its cycle.
Well thanks a bunch for all your help.
I will keep you posted.
salutka is offline
Old 15th September 2008, 12:46 AM   #10
My statement was: 470K + 100K (not 570K as a single resistor). To compensate for capacitance deviations he should use the circuit as is - with a trimmable resistor.
Old 16th September 2008, 11:49 PM   #11
I have a problem with my timer, I have it connected to a clean 12v power supply, it performs great for the first five minutes then it stars to blink constantly, if I kill the power for 1/2 hour and start it again it works for the first five minutes. Any suggestions?
salutka is offline
Old 17th September 2008, 07:57 AM   #12
change the capacitor
it could be that you have a monday morning capacitor that sliped through the quality control
Robert-Jan
rjvh is offline
Old 17th September 2008, 01:08 PM   #13
Robert-Jan
could as well be his private "monday morning". Electrolytic capacitors don't like reverse charging at all!
Go check it!
Hans
Old 19th September 2008, 08:20 PM   #14
Turns out it was my Monday morning capacitor, btw the circuit works great.
Thank you all so much for your time and help, I really appreciate it!
salutka is offline
Old 20th September 2008, 03:28 AM   #15
Always triple-check!
led, timer
555 timer help thekyguy11 Electronic Projects Design/Ideas/Reviews 23 9th October 2009 09:21 PM
555 Timer Help Frosty_47 General Electronics Chat 11 17th May 2008 05:58 AM
RQ : Speaker's Timer / Conference Timer red-devil Electronic Projects Design/Ideas/Reviews 0 13th April 2004 12:37 AM
Help on timer buloi123 Electronic Projects Design/Ideas/Reviews 7 19th March 2004 04:11 AM
555 timer rukid88 General Electronics Chat 4 7th December 2003 08:52 PM
