| I'm looking to build a timer (it was suggested I look to use a 555) to turn on and off a load (which I will use an external relay driven by the timer). The on time will equal that of the off time. The time will be approximately 13 minutes. I've done a bit of research on creating timers using the 555 chip and all the designs I found were to achieve cycle times in under 1 second. So, when I started to modify the values of the R & C to achieve 13 minutes I started getting some pretty large numbers. Then I found a software program called 555 Timer Pro. When I used to check my calculations the program warned me that the high resistor requirements needed to achieve t=13 minutes would result in too little current to drive pin 6. So, now I'm out of my area of knowledge. Can anyone suggest a design that would meet my needs here? Thank you in advance. Frank | |
| 555 won't cut it. A small microcontroller could do it. | |
| Any additional direction would be very helpful. I really don't know anything about "micro-controllers". Thanks for the guidance. Frank | |
| Have the 555 drive an n stage counter. If the 555 puts out 1 Hz and 13 minutes is 780 seconds, a 10 stage [2^10 = 1024] counter should do it. The other way is to cascade CMOS 555 chips. Last edited by Willbe; 10th September 2008 at 09:14 PM. | |
| Use a CD4060 which is an oscillator and a divider or a CD4541 oscillator timer.
| How accurate does this need to be? If you use cheap 20% tollerance ceramic capacitors for the oscillator, the time could vary between 10:24 and 15:48 minites.
| 555 could not be used for a t=13 minutes for sure u can use a 8051 microcontroller with the program using wait states for 13 minutes | |
| I think Willbe's idea is a sound one. A 555 driving a CD4040 with the divide by 9 output would give equal times of 6.5 minutes if the 555 is set for astable period of about 0.76 seconds. The 4040 would probably drive a solid state relay to turn power off and on. With the 555 a regulated power supply would not be needed as the 555 period would not change with a unregulated power supply where the 4060, or 4541 both as oscillators and dividers would change frequency with varing supply voltage.
__________________ The great thing about electronics is unlimited ways to do the job. The only limit is one\'s imagination. I generally think my way is best. Show me a different way. I have an open mind. | |
For under a $1 you can get a PIC that can be programmed to do exactly what you want and with fewer parts. Once more I forget where (and I can not find it) a site that used to sell small pics to replaces timers and various other simple chips/apps. They ceased their commercial effort and offered the code to the public for free download.
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) Last edited by 3v0; 11th September 2008 at 10:55 PM. | ||
Hans
__________________ Proper Planning Prevents Piss Poor Performance | ||
| Maybe... but a LVP would cost next to zero. I have wanted to play with the low voltage programming but with a number of programmers on hand have not yet found the motivation. You would have to get a chip the supported LVP. Or if you have a friend with a programmer you could use a boot loader. IMHO either you want to program or not. Cost is not a real factor.
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) | |
| 555, timer |
| 9v + LED = time? | e-amature | General Electronics Chat | 10 | 1st February 2007 10:18 PM |
| first time ever here | cooltechfreak | Electronic Projects Design/Ideas/Reviews | 8 | 23rd October 2006 10:26 AM |
| its PCB time | zachtheterrible | General Electronics Chat | 29 | 10th November 2004 06:18 PM |
| Enquiry For Discrete Time Convolution & continuous time | shermaine | General Electronics Chat | 3 | 4th August 2004 09:25 PM |
| variable 5,10,15,20 minutes timer circuit | james | Electronic Projects Design/Ideas/Reviews | 3 | 24th October 2002 03:24 PM |
