Old 10th September 2008, 03:45 PM   (permalink)
Default -ve from a +ve rail?
i have a 24V dc bus, and i need a +15V and -15V rail for some opamps....how do i create a -15V rail?
i found a chip pt6645, but i cant get ahold of 1.
b.rad is offline
Old 10th September 2008, 04:52 PM   (permalink)
http://cache.national.com/ds/LM/LM2576.pdf figure 10 shows what you want.
Diver300 is offline
Old 10th September 2008, 05:46 PM   (permalink)
looks good, going to give it a bash, thanks alot!
b.rad is offline
Old 10th September 2008, 06:20 PM   (permalink)
What do your op-amps do?
It's possible you could use AC coupling capacitors if it's AC or use a virtual earth circuit, if it's DC.
Screen name: Aloone_Jonez
Hero999 is offline
Old 10th September 2008, 06:26 PM   (permalink)
The op-amps are for signal conditioning (offset/gain) before going into a dsp, so dc application. Another student developed the cards, and I don’t want to go and redesign his work unnecessarily. The stipulate rails for the circuitry is +- 15V, but 12 will work just as well.
b.rad is offline
Old 10th September 2008, 06:42 PM   (permalink)
How much current does it use?
A virtual earth circuit will probably work.
http://www.electro-tech-online.com/e...wo-7805-s.html
http://www.electro-tech-online.com/g...l-grounds.html
Just ensure that all the circuits operating from it that interface with each other all use the same virtual earth for the 0V rail.
Hero999 is offline
Old 10th September 2008, 09:44 PM   (permalink)
Further to my rather short posting, if you change to an LM2576HVT-15 it will give 15V. If you are only powering a couple of op-amps it is a lot more powerful than you need, but you can use that principle with just about any buck regulator.
Diver300 is offline
Old 10th September 2008, 10:18 PM   (permalink)
Charge pump converters are suitable when low power is required. If +/-12 Volts are fine, you can invert +12 V with an ICL7662 or similar (newer?) ICs. Your input voltage limits the choice of the converter amongst few devices, though.
http://datasheets.maxim-ic.com/en/ds/ICL7662-Si7661.pdf
eng1 is offline
Rail To Rail Op amp gramo Datasheet/Parts Requests 12 21st March 2007 08:23 PM
Rail gun formulae. Hero999 Math and Physics 11 1st December 2006 10:10 PM
Duel rail voltage Gregory Electronic Projects Design/Ideas/Reviews 10 1st October 2006 11:31 PM
How do I make a -5v rail ? Screech General Electronics Chat 36 28th September 2005 10:00 AM
rail-rail opamp output Styx General Electronics Chat 4 8th June 2004 08:08 PM
