| I want to build a circuit that uses a single electrode that can act as both an input and an output. I have attached diagram of my first guess of how to do this. Do you think this would work? I'm a newbie, so be nice Last edited by xaviergisz; 10th September 2008 at 01:51 PM. | |
| Try telling us EXACTLY what you're trying to do, and not how you think it needs to be done. | |
| I want to build a neural network out of modules (i.e. blocks). Each module has 6 sides with one electrode on each side. The modules are stacked together so that one electrode on one module touches one electrode on another module. Each electrode acts as both an input and an output for the simple analog circuit inside each module. I need to split the input and output at each electrode so I don't get feedback within the module circuit. | |
__________________ "Remember, you're special.....just like everyone else." Last edited by rezer; 11th September 2008 at 06:06 AM. | ||
| The goal of any neural network is ultimately machine AI, so I suppose mine is no different. The analog signals could be any type of sensor input, for example the signal for one electrode could be from a single pixel of a CCD array. | |
| What are you using as a voltage reference? Torben
__________________ Curiosity was framed. Ignorance killed the cat. | |
| ah, good question Torben. Initially the modules would be be connected to and powered by positive and negative/earth rails. Ultimately, I would hope to power the modules wirelessly or perhaps using an "Avramenko one wire circuit" (see this discussion for details). | |
Remember, copper is expensive. If there were a reasonable way to skip running ground wires all over everything, then designers would do so. How large will the blocks be? What experience do you have with electronics? Torben Torben
__________________ Curiosity was framed. Ignorance killed the cat. | ||
| At the moment I want to focus on the single electrode input/output circuit using positive and earth rails rather than the pitfalls of wireless (or single wire) power transfer. The blocks would be as small as possible. I was thinking the circuit would fit on a 5x5cm PCB, thus a module would be 5x5x5cm. I took a course in electronics a while ago but never used these skills outside of the classroom, so I consider myself at an intermediate level. Last edited by xaviergisz; 11th September 2008 at 10:46 PM. | |
| What are you using as memory for the learning function? If you are using micros as the intelligence why not just use the UART? I must admit to not have read up about neural nets. | |
| My idea is a fully analog neural network, so I don't want to use a UART or any other digital transmission device. For memory I'm thinking of using a memristor (or probably an active equivalent of a memristor). | |
Although it sounds a completely useless idea to be honest?. | ||
Basically this is a toy/tool for investigating analog neural networks. It may turn out to be completely useless, but I will not be convinced until either a) someone provides a compelling reason why it wouldn't work, or b) I test it out myself. | ||
| You need to provide the circuits of the nodes, overwise how can anyone suggest interconnections. Quote:
| What I want to know is: can a single electrode be used for signals going into and coming out of an analog signal processor?If the answer is "yes, it's possible", I can move onto to considering other elements of the project. If the answer is "no, it's impossible", that's fine, I can reassess the feasibility of the project. I don't understand how the "circuits of the nodes", "how complicated is each node going to be" and "how many were you thinking of" is significant to answering the question. To help visualize the problem, let's say the voltage at the electrode, input and output are all within the range from 0 to 5V. | |
| Single output equivalent of ULN2003A Darlington Transistor Array? | llrjt100 | General Electronics Chat | 3 | 9th May 2006 08:18 PM |
| Looking for multi input single output to headphone device | ZebraTJ | General Electronics Chat | 1 | 5th April 2006 12:21 PM |
| Galvanic Skin Response output display/electrode | shamog | Electronic Projects Design/Ideas/Reviews | 2 | 23rd December 2004 04:29 AM |
| Help! Input/Output | Keiou | Micro Controllers | 1 | 9th March 2004 07:49 PM |
| input output code for C# | 20303675 | Electronic Projects Design/Ideas/Reviews | 0 | 17th August 2003 03:33 PM |
