Old 8th September 2008, 05:47 PM   (permalink)
Lightbulb Electronics Gods.. Give me insight
My name is Noah Benzing and I'm attempting to fabricate a wiring harness for a Hammond tonewheel generator.. it uses 96-wires/pins...
This had been tried before with disastrous results.. using a ribbon cable....
The crosstalk was so bad it rendered the organ unplayable.
How can I eliminate cross talk in a situation such as this? I would like to take someone's failure apart and turn it into a sucess..... enlighten me.
Please e-mail me at:
noahbenzing@gmail.com
NoahBenzing is offline
Old 8th September 2008, 06:50 PM   (permalink)
Running a conductive ground plane, say grounded aluminum foil, very close to the ribbon greatly weakens crosstalk. Try it first with your existing setup.
Supposedly each conductor has an "image" on the other side of the ground plane, like the image in a mirror. The closer the virtual image is to the actual wire the more the fields cancel and so you get ~ no crosstalk.
This was why the 6.3 VAC filament leads for vacuum tubes were pressed against the ferrous metal chasses.
Willbe is offline
Old 8th September 2008, 07:16 PM   (permalink)
It not totally clear from the picture, but it looks like twisted pair wires in the ribbon. If so, are both pairs carrying signal, or is one of the pair a ground? If both carry signals, that would certainly be a source of crosstalk. In that case replace the twisted pair with a ribbon cable with parallel wires. That would greatly reduce crosstalk.
Carl
crutschow is offline
Old 9th September 2008, 06:20 AM   (permalink)
It will depend on what he's sending and the signals used. Twisted pair cabling is often used to reduce noises in an environment such as this. I work on systems that use this type of cabling for filtering. But, then again, my systems are designed for it's use. But in this installation, it looks like a patch job. Is that right? If that's the case, crutschow would be correct. Try the flat ribbon cable. Is the system pre-wired already (in it's final stage minus the cross-talk issue). Or do you have more work to do?
"Remember, you're special.....just like everyone else."
rezer is offline
Old 9th September 2008, 08:46 AM   (permalink)
Default Tonewheel Generator Wiring Harness Project
Hey guys I really appreciate all the feedback on this project. The picture up above is from someone else's attempt to fabricate a wiring harness for a Hammond tonewheel generator *electronic organ*... there are 96 wires coming out of the generator, each one a different frequency for each key on the organ's manuals. I've thought of using this connector....
[BR]
[BR]
The current harness is a massive bundle of cloth covered wires *you have to remember that this instrument was manufactured in July of 1962*... not like the ribbon cable wires seen in the photo. So I have room to play to avoid his same pitfalls.... which is why I came here.... lol.
The organ in this particular... enthusiast's wiring project is a B3.. the king of Hammond organs. Mine is an L-103.. a much smaller "spinet" model, but uses an almost identical tonewheel generator *spinning phosphor bronze discs next to electromagnetic pick-ups that generate an oscillation that is what we know as the Hammond "sound".
If it would help to see what I'm working with and if you have an open mind.... look at my video near the end and you can see the harness I'm working with going across the brass cover of the tonewheel generator and spreading out so that all 96 wires can connect to terminals that run the entire length of the generator....
Fast forward to 7:13 and watch up to around 8:10
http://www.youtube.com/watch?v=y34478fzY3M
So... looking at what I have to work with and not being in the middle of an imminent failure such as my predecessor... what could I possible do to make a connector that will modularize the tonewheel generator that won't introduce crosstalk?
Old 10th September 2008, 01:02 AM   (permalink)
Do the original wires have any shielding, either individually or over the whole bundle?
Carl
Old 10th September 2008, 01:17 AM   (permalink)
A standard practice for crosstalk is to use a ground wire in between each signal wire. So you would have S-G-S-G etc...
Forget injuries, never forget kindnesses.
Mikebits is offline
Old 10th September 2008, 01:26 AM   (permalink)
Slowing the signal rise/fall times will also reduce crosstalk.
Willbe is offline
Old 10th September 2008, 02:09 AM   (permalink)
I believe the tone wheel generator rotates at a constant speed, and the frequencies are set.
To slow the rise/fall time would be to alter the frequencies, since they are analogous, thereby altering the sound.
rezer is offline
Old 10th September 2008, 05:43 AM   (permalink)
I assume you're referring to flat ribbon cable. It works particularly well with that.
Carl
crosstalk, hammond, noah benzing, noahbenzing, organs
Insight required schand10 General Electronics Chat 22 22nd March 2008 03:01 AM
The Petty Gods Of Electronics.. 3v0 Chit-Chat 16 27th September 2007 07:31 AM
Need some help from the Pic gods (PWM measurment) jrz126 Micro Controllers 10 4th November 2005 09:09 AM
Insight needed Veearesix Electronic Projects Design/Ideas/Reviews 7 16th March 2004 07:18 PM
PLEASE WEBCAM CIRCUIT NEEDED CAN THE gods IN HERE HELP? timothy Datasheet/Parts Requests 0 21st October 2003 06:33 PM
