| I am using two number of PIC18f452 microcontrollers. TX1 pin of first PIC18f452 connect with RX2 pin of second PIC18f452 & RX1 pin of first PIC18f452 connect with TX2 pin of second PIC18f452 Now i want to see this two way communication over my PC through serial port without any intruption. Is it possible? What circuit will be required to make it possible
__________________ ash | |
| What kind of data are you sending? Is it just ASCII text? For the serial port, you will need an RS-232 transceiver, http://www.maxim-ic.com/quick_view2.cfm/qv_pk/1798 unless the PIC µC has them inside. I doubt it, but I'm not an expert on PICs. For plain ASCII text you could view the data using Hyper Terminal. Is this just for monitoring purposes, or will the PC be playing a more active role?
__________________ "Remember, you're special.....just like everyone else." | |
| Yes i am using max232 IC for PC . I want to TX and RX from PC as wel when ever i need to send and receiver data. Yes its a simple ASCII text and i want to see it on hyper terminal
| You could also use a PICkit2/Junebug to get the serial working with the UART tool. Then add the RS232 level shifter after you have that much working.
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) | |
| I think that so far that the responders of this posting have failed to understand the complexity of what the OP is wishing to do. "Now i want to see this two way communication over my PC through serial port without any intruption." He wants to be able to monitor (and send to?) TWO serial data links using ONE PC comm port. That is the two PICs are sending and receiving to each other and he also wishes to be able to monitor and send into these two links with his PC. That can't be done without some kind of external ORing logic circuity. Using TWO PC comm ports with two instances of hyper terminal loaded could solve for the PC monitoring both links (receiving) part, but there would still be external ORing logic needed for the PC to be able to send to either PIC, again as the two PICs are also wired to each other. While one can wire a single output terminal to more then one input terminal, one can't just wire two output signals together to a single input terminal, they will not play well together. Am I missing something? Lefty
__________________ Measurement changes behavior Last edited by Leftyretro; 8th September 2008 at 07:27 PM. | |
| You are correct. I misunderstood what he was wanting to do. It would be a neat additional function for the PICkit2. Iy would not be much work if one had source code.
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) Last edited by 3v0; 8th September 2008 at 07:34 PM. | |
| I see. After re-reading his post, I agree. Two instances of Hyper Terminal would be the way to go. It would probably be easier to just use Com1 and Com2, if available. I think it could be done by outputting both TX lines and inputting both RX lines to the PICs. This would be the obvious hardware solution. Controlling it through software would be more difficult. Perhaps an external trigger or maybe something as simple as a switch to "halt" communications between the PIC when Hyper Terminal is used to send data. Does this sound logical?
| If it can be done with some kind of external Oring circuitry, then i would like to know your idea in detail with a logic circuit diagram. keep the following things in your mind while making logic circuit diagram 1. I want to monitor both PIC TX1 and PIC TX2 on my PC via RS232 without any switching. 2. & want to send data from my hyper terminal via RS232 to my PIC RX1 & PIC RX2 without any switching
To monitor your TX lines is no big deal. Use Com1/2 with two instances of HyperTerminal running on your desktop. How will the flow of traffic work in your system with two PICs talking to each other and you making changes on the fly? What do you envision?
__________________ "Remember, you're special.....just like everyone else." | ||
| RS232 is point to point (Two devices), plus your PC's RS232 port is too high a voltage for the TTL level serial ports on the 18F452. RS485 is more practical for multipoint serial communications. | |
| Switching is not required either mechanically or programitacally. & only ONE com port is available with my PC. If two transmit line can monitor on two seperate COM ports then how to send data from PC to two PIC receive lines from PC. As we know one transmit and many receive can be possible but many tranmit and one receive can not be possible without having some sort of circuitry. And i am asking for the same kind of circuitry.
| Yes, obviously. He mentioned in an earlier post he was using a MAX232 to his PC. I didn't feel the need to mention that since he already has it figured.
| Yes RS485 could be the solution but i will need 6 number of IC's to finish this task because it is a half duplex. is there any other simple hardware less circuitry solution availabe/possible?
What about an RS-232 data switch? http://www.csdevel.com/manuals/E-data.pdf
| I missed the post about the MAX232, anyway you can monitor only one channel per serial port. To monitor both directions you'll need two serial ports on your PC. Lot's of programs out there can do "Serial Port Sniffing" http://www.serial-port-monitor.com/ Also RS422 is full duplex and 10 device multidrop. Take a look at www.rs485.com Last edited by blueroomelectronics; 9th September 2008 at 06:36 AM. | |
| serial communication from PIC to PC | flemmard | Electronic Projects Design/Ideas/Reviews | 10 | 11th September 2007 12:07 PM |
| Serial communication | Electronics4you | General Electronics Chat | 4 | 13th March 2007 07:12 PM |
| serial communication | alfian andri trianto | Micro Controllers | 2 | 9th July 2005 02:59 AM |
| serial communication | jaikanth | General Electronics Chat | 1 | 12th December 2004 04:43 PM |
| serial communication | TKS | Micro Controllers | 0 | 1st September 2003 09:38 PM |
