Old 9th September 2008, 06:46 AM   (permalink)
can i send data to PIC RX1 & PIC RX2 from my PC using two COM ports.
Rezer RS485 is a solution of what i have asked but its emplementation required 6 No. of IC's for a fully functional debugging of data on a single COM port.
I need a simple low cost less circuitry CIRCUIT, so that i will easliy add it up to my all serial port related projects.
ash
ashraf is offline
Old 9th September 2008, 08:59 AM   (permalink)
Ash;
I told you it was more complex then first impressions
It's a little difficult to just draw you a design as one could use more details about the application and use. I assume this is for testing and troubleshooting the design and not required for the final product?
If it's just for testing then you need to define if you can utilize a PC with two comm ports or can you have two PC systems available for the testing period? Having two PC would make the testing session a little more straight forward as you won't have to figure out which instance of hyper terminal is active and which COMM port is monitoring which of the two PIC data lines.
If you have only one PC with one COMM port then you have the problem of output data from the PC. How will you determine which PIC signal input will receive the data from the PC, #1 pic, #2 pic or both at the same time without some kind of manual switching function?
Also can the two PICs be sending data to each other at the same time or will data only be sent in one direction at any specific time (half-duplex or full duplex)? If full duplex then you will defenitly need two COMM ports or two computers to do the monitoring as ORing two PIC data streams with one COMM input port will garble data if the two PICs send data at the same time.
The ORing logic needs to be performed on the TTL side of the max232converter(s) of course. If I recall the RS-232/TTL converters utilize a negative logic such that when no data is being send (steady mark condition) the TTL level is at a high state. If that is fact then the ORing function can be performed using a 2 input AND gate (74LS08 should work). If the serial logic level is using positive logic (steady mark condition = TTL high state) then a 74LS32 OR gate would perform the proper function. Each 74LS08 (or 32) has four gate functions avalible.
This ORing function gate would be used where ever you want to have two TTL output pins sending to one TTL input pin. How many Oring function you need again depends on the number of COMM ports or computers you have avalible for testing.
Lefty
Measurement changes behavior
Leftyretro is offline
Old 9th September 2008, 09:29 AM   (permalink)
On a PC with two serial ports, the easiest solution I can see is to write a program that relays the signals. I.E. what comes in com1 goes out com2 and vice versa. It would then be very simple to monitor what is passing back and forward and inject additional data as necessary. There will be a latency of 1 byte between the pics but I can't see any other way to do this without external circuitry.
Pommie is online now
Old 9th September 2008, 03:59 PM   (permalink)
Might be fun to daisy chain the serial ports, you'll have to echo the data though.
So TX1 to RX2, TX2 to RX3, TX3 to RX1
Puddles of fun.
Bill
Smart Kits build Smart People
Old 10th September 2008, 04:44 AM   (permalink)
Yes it is for testing and trouble shooting the design
Only one PC & one COM port is available.
#1 PIC & #2 PIC response command can be different. For exampl #1 PIC respond on YES & #2 PIC respond on NO only. This can be done in programming.
Yes we will receive garbage data when both PICs send data at a time but this can be fixed by proper time slicing.
Need a schematic diagram to elaborate it practically
ash
ashraf is offline
Old 10th September 2008, 03:16 PM   (permalink)
Tell you what, why don't you draw something up and post it and we can then tell you if it will work properly or not It's is in fact your project.
Lefty
Old 10th September 2008, 04:11 PM   (permalink)
Puddles of fun.
I did something like that once. The user needed to have up to 4 boxes connected to the serial port on a workstation. I used a RS232 based network with addressed packets.
On powerup boxes were setup not to pass packets to the next box. That allowed the workstation to talk to the first box and assign it an address. Then turn on the connection to the next box and assign it an address. The boxes did not speak unless spoken to so the workstation needed to poll periodically.
3v0 is offline
Old 11th September 2008, 05:57 AM   (permalink)
Sorry & thanks
Let me do it myself
ash
ashraf is offline
Old 11th September 2008, 06:16 AM   (permalink)
Originally Posted by ashraf View Post
Sorry & thanks
Let me do it myself
Nobody's giving up here. This is a help forum. But you need to help us, help you. We're not mind readers and it is hard at times visualizing someone elses visualization of what they want (That means your not in the design stage yet). It would help if you at least had a visual representation of what you want, and post it. We're more than willing, but you have to be as patient as we've been with you.
"Remember, you're special.....just like everyone else."
rezer is offline
Old 11th September 2008, 08:18 AM   (permalink)
Thumbs up
You are right rezer. We all are here to help each other.
I always wish all of you to help me technically.
Sorry for the unprofessional attitute, specially from Lefty
ash
ashraf is offline
serial communication from PIC to PC flemmard Electronic Projects Design/Ideas/Reviews 10 11th September 2007 12:07 PM
Serial communication Electronics4you General Electronics Chat 4 13th March 2007 07:12 PM
serial communication alfian andri trianto Micro Controllers 2 9th July 2005 02:59 AM
serial communication jaikanth General Electronics Chat 1 12th December 2004 04:43 PM
serial communication TKS Micro Controllers 0 1st September 2003 09:38 PM
