| Thanks everybody for your help. Being less experienced, i need to spend some more time trying to understand your tips and then i will get back to you. | |
Since their internal structure is almost the same (except for CMOS) they should behave similar under the given conditions. I just chose the 7556 because of the long time delay of 180 seconds, a bit hard to achieve using a 556 because of the minimum threshold current. The circuit is easiest to build up using one astable and one monostable. The problem is just the high voltage - used for supply it would kill the the chip within no time. Hans
__________________ Proper Planning Prevents Piss Poor Performance Last edited by Boncuk; 8th September 2008 at 02:07 AM. | ||
| The CMOS and TTL ICs do behave differently. If it's a CMOS IC it'll probably go into destructive latchup, if it's TTL, the base-emmiter junction of the output transistor will breakdown and be destroyed.
__________________ Proper Planning Prevents Piss Poor Performance | ||
| art-circuit-design question: IR pulse filtering and ADC? | AweLucid | Electronic Projects Design/Ideas/Reviews | 9 | 9th June 2008 06:15 AM |
| Need Help! A circuit that will produce only 1 pulse | menirva | Electronic Projects Design/Ideas/Reviews | 5 | 15th April 2008 05:10 PM |
| The ECG(heart Pulse) circuit problem... | kingkong83 | Electronic Projects Design/Ideas/Reviews | 15 | 11th October 2004 07:48 PM |
| Pulse timer type circuit help........ | ninewgt | Electronic Projects Design/Ideas/Reviews | 3 | 28th March 2004 11:02 AM |
| 10 Second Delay circuit from a 3v pulse | NX5 | Electronic Projects Design/Ideas/Reviews | 1 | 29th July 2003 03:07 PM |
