| I would like to design a radio controlled activated relay. When I press a button it will trigger the relay and it will cause circuit breakers to trip | |
| Just try it, if the relay coil takes less power than the motor it should work. Warning: using relay contacts to cause a short circuit is *not* a good idea. You mention circuit breakers tripping, I guess you mean MAINS circuit breakers. If so, you will see your relay contacts vaporise instantly and perhaps start a fire - take care! | |
| Wha? a relay is an automated switch... since when does a switch "vaporize".. as long as its rated high enough hes all set. the hardest part of that circuit is the transmitter/ receiver part.... id like to see what hes using
__________________ Do no meddel in the affairs of dragons, for you are tasty and go good with ketchup. | |
| Jaw, read the original message again. The way I read it he wants to create a short circuit by remote control. Now, if you do that with mains power you need mighty big relay contacts or a very fast fuse/circuit breaker to safe the relay contacts for another go. There could be several hundreds of amps for a tiny instant across the contacts. If I wanted to do that remote control power switch off trick I would fit an ELCB (earth leakage circuit breaker) and then remotely short the life wire to earth. The ELCB trips instantly with no big current across the relay contacts, just 50mA or so. Now, kevinloh, tell us what you *really* want to do | |
| I'm just tryin to see how fast the circuit breakers trips the circuit. So, Can I use the contacts one is for live and one is for ground? | |
