| | #16 | |
| Quote: | ||
| | #17 |
Hello, Finally i calculated these values for R1 & R2 & Rc & RE... Now the problem i am getting is that my calculated values and measured values is not the same.. Here is my circuit : Using Beta = 110 as on the datasheet : and also using approximate analysis.. My calculated values are as follows: Vb=1.597V Vce= 5.13V Ic~=IE=0.897mA Vc=6.03V Ib=8.08 micro.Amps Input inpedance = 4791.96 Ohms Output impedance = 5000 Ohms Vo=4.44V Can anyone check my circuit and let me know if its in good working condition? Thanks in advance... | |
| | #18 |
well niceboy sorry to say this but you have done some errors in your calculation: First of all you have calculated the the dc op point vb not the one with the i/p signal. I/p impedance is correct, s far as the o/p impedance is 5k(you are correct) you high pass filter has F3db=3.325hz the simulator which ever you have used is fairly accurate but i would advise you to use ltspice very helpful to understand all the details. here are some of the values that i cal dc op point not simulated it yet. vb=1.5969(you are correct) ve=? for ve taking vbe=.6 then Ve=Vb-Vbe=.996v(simulator is nearly correct) Ic=(dont know how to get the similiar symbol)Ie=Ve/Re=.996Amps(simulator is nearly correct) Vc=Vcc-IcRc=5.04v(you have connected Vc incorrectly in your figure) Gain=Rc/Re=10 so approximating the o/p voltage i think your o/p voltage is a bit high but you have hugely overcalculated in your Vo calculations.
__________________ I just cant come up with a good one! | |
| | #19 |
An output impedance of 5k is too high to drive a 10k load, it'll be fine to drive 100k though, if you want to drive a 10k load the output impedance should be 1k maximum but I'd recommend even lower.
| | #20 | |
| | #21 |
| The output impedance of the transistor amplifier is 10k and it has a 10k load which cuts its output in half.
| | #22 |
then what would be the best output impedance plz? so that i can work out the transistors. thx | |
| | #23 |
I've just told you.
| amplifier, bjt, calculation, common, emitter, resistor, single, stage |
| Common Emitter Amplifier Help | Callo1234 | General Electronics Chat | 9 | 25th April 2008 09:48 AM |
| Upper Cut off Frequency in Common Emitter Amplifier | Callo1234 | General Electronics Chat | 4 | 18th April 2008 05:13 PM |
| common emitter circuitry. | mybuickskill6979 | General Electronics Chat | 29 | 15th February 2007 08:03 PM |
| Single Stage Common Emitter Amplifier part2 | ad353 | General Electronics Chat | 4 | 7th June 2004 07:58 PM |
| Single Stage Common Emitter Amplifier | ad353 | General Electronics Chat | 2 | 7th June 2004 05:52 PM |
