Old 29th August 2008, 02:33 PM   (permalink)
Default Battery Monitor Circuit- Need Help
Hi, New here, been out of the electronics field for a bit and need some help with a circuit. I need to build a battery monitoring circuit that will monitor two AA cells and light a LED when the voltage for these cells is low. I guess that trip point to be around 2.1 to 2.4 Vdc. I have searched the internet and found voltage monitoring IC's etc. by Panasonic and ON Semiconductor, but none are readily available. These also have 3000 part min. qty. orders. I did manage to get some samples from ON Semi for a NCP301LSN22T1G voltage detector. They are microscopic and I will never be able to solder any thing to them! Can I use a comparator circuit? LM393? Any help would be appreciated!
rainyday101 is offline
Old 29th August 2008, 02:35 PM   (permalink)
The ICL8211 ic a battery monitor.
datasheet at: www.datasheetarchive.com
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is online now
Old 29th August 2008, 02:49 PM   (permalink)
Thanks, I looked up the IC and like it, but it is microscopic in size! That is about the size of the ones I have from ON Semi. With it that small I wouldn't circuit board mount it and would need to solder wires to the legs. I don't have anything to solder that small and maybe the ability to do so. In my time away from this field I can't believe how small things have gotten! Any ideas appreciated. Thanks.
Old 29th August 2008, 03:00 PM   (permalink)
Look for a MAX8211CPA:
http://www.newark.com/68K5030/semico...questid=127695
Newark Electronics...in an 8-Pin DIP.
Ken
KMoffett is offline
Old 29th August 2008, 03:30 PM   (permalink)
Yes, use a comparator with hysteresis and a bandgap voltage reference. Piece 'o cake!
Willbe is offline
Thanks!!!! That is exactly what I am looking for!!!
Old 29th August 2008, 04:08 PM   (permalink)
Its also an 8pin DIL plug in package as well a SMT..
Eric
PIC tutorials:
Battery Monitor Circuit rob81 Electronic Projects Design/Ideas/Reviews 9 7th January 2007 06:03 PM
LM3914 Help - Battery Monitor Circuit Needed! Skyone Electronic Projects Design/Ideas/Reviews 19 15th August 2006 11:32 PM
MAX6433- Low Battery Monitor? arrow General Electronics Chat 5 24th August 2005 06:14 PM
24v battery monitor cool-agent Electronic Projects Design/Ideas/Reviews 2 3rd July 2004 02:02 PM
battery monitor kekeke Electronic Projects Design/Ideas/Reviews 1 18th August 2003 05:44 AM
