Hi folks, I'm building a forced air chicken incubator and need help with an inexpensive electronic device to monitor and control relative humidity in the unit. The circuit needs to be capable of: 1) 110v operation 2) detecting the internal humidity, then activate a small, submerged ultrasonic device (from a "cool mist" humidifier) to raise the internal humidity to 65%, then shut off the device. 3) Have a second mode of operation that would perform the same as above but raise the internal humidity to 75%. Any ideas would be appreciated. Thanks! | |
| | #2 | |
How do you know what CFM and air speed to use? Does the incubator generate humidity on its own? Last edited by Willbe; 27th August 2008 at 09:46 PM. | ||
You can get cheap humidity sensors. For heating you could use an mid IR lamp. http://www.rapidonline.com/Electroni...y-sensor/80511
Thanks for the Link Hero. That's perfect. Willbe: Yes, the fans move 26 cfm, but the incubator doesn't generate it's own humidity (not yet at least). I've tried using a sponge wick in water tray method, but the unit doesn't get any higher than 40-45% at an operating temp range of 99 - 100F. | |
Whoa... wait aminute. I'm stuck in the middle of the New Evil Roman Empire (US). Anyone know of a link to a good electronics site like the one Hero sent me? | |
| | #6 |
I have an chicken incubator that holds about 500 eggs with an automatic humidifier. One that hooks up to a water hose and it has a dial that you turn up or down to adjust your humidity. Now it is stuck in the open and will not shut off. Can anyone recomend any input since the company went ouy of business years ago.
| | #7 |
Are you looking for a solenoid valve? & yes I know this is an old thread...
__________________ Mike2545 | |
| | #8 |
No, but it controls one. I think it works like is a humidistat. I tried a humidistat but the one I used has a variance of about 10-12 % I have checked other websites but none list what percent it kicks on and off. I need something that has a 1-2 percent | |
| chicken, humidifier, incubator |
| incubator circuit help* | kyrie2 | Electronic Projects Design/Ideas/Reviews | 45 | 3rd March 2009 03:11 PM |
| Chicken coop door control | perthdownunder | Electronic Projects Design/Ideas/Reviews | 9 | 16th December 2008 10:05 PM |
| Bipedal Chicken Walker | ultimatekiller | Robotics Chat | 2 | 9th October 2007 04:45 AM |
