Old 26th August 2008, 11:39 AM   #1
Question monostable timer
Hi, can anyone pse help a novice.
I am building a model railway control panel and I am stuck. On my layout I have station stops activated by the loco triggering a reed switch,
this works fine. I decided to add a monostable timer to automate the length of time the loco is stopped. A DPDT C/O MIN TOGGLE SWITCH controls this
ON manual stop - OFF no stopping - ON timed stop. I made a tester and all worked fine but I now have a problem that some of the timers
when switched on go straight into timed mode instead of waiting for the reed switch to trigger it. Can anyone suggest a retro fit to cure this ??
I ask for a retro fit because I have fitted 40 of these timers already and about 50% have this problem.
Thanks eddy
EDDY99 is offline
Old 26th August 2008, 12:05 PM   #2
Thanks eddy
hi eddy,
How are you debouncing the toggle switch.?
Also what type of monostable.?
ericgibbs is offline
Old 26th August 2008, 12:20 PM   #3
Its a basic 555 monostable, "debouncing" ? as u can tell I am a complete newbie to electronics, but willing to listen and learn.
EDDY99 is offline
Old 26th August 2008, 12:31 PM   #4
The problem is that with most mechanical switches you dont get a single contact action between the contacts.
They bounce on/off when closing for a few millisecs, as the logic is so fast its senses all these on/offs as signals. These bounce signals can cause your circuits to do unexepected events.
So between the switch contacts and the 555 you need a simple resistor and capacitor circuit.
If the switches are really 'bouncy' you may need an additional ic, eg a 40106 or 74HC14 Schmitt trigger.
Do you follow OK.?
Old 26th August 2008, 12:36 PM   #5
following so far
EDDY99 is offline
Old 26th August 2008, 12:52 PM   #6
following so far
This shows some options, there are many.!
The bottom two are my choice.
Any questions, ask.
Old 26th August 2008, 01:00 PM   #7
Thanks very much, should be able to manage that, do u have any values for the V & R in the first one (top left) power supply is 12DC
EDDY99 is offline
Old 26th August 2008, 01:21 PM   #8
Look at these two options.
I prefer the Schmitt.
EDIT: as you are using 12V, the 74HC14 should be replaced by a HEF40106.
Old 27th August 2008, 12:38 AM   #9
Third option ...
That one doesn't care if the switch is debounced since it's non-retriggerable until it times out.
Triggering is done with a positive going pulse edge.
Hans
Boncuk is offline
Old 27th August 2008, 09:38 AM   #10
Thanks very much for the quick replies, I have tried a couple of the suggested circuits but anything that alters the power to the switch has a knock on effect of making the other functions of the switch inop. The switch is used to trigger relays for point motors/coloured lights etc. When switched to timed all I am doing is powering up the monostable ready to be triggered by the loco reed switch, if I turn the v-pot to zero it behaves as normal but if the pot is turned up it goes straight into timed mode, after the set time it does reset it self and acts normal.
EDDY99 is offline
Old 27th August 2008, 10:05 AM   #11
hi eddy,
Is this the actual circuit you are using.?
Old 27th August 2008, 10:10 AM   #12
The circuit is the same, made a couple of changes, removed the power in switch so it is powered from the panel switch, the v-pot is also mounted on the panel and the buzzer has been replaced with a relay
EDDY99 is offline
Old 27th August 2008, 12:38 PM   #13
Hi Eddy,
that circuit is retriggerable. I didn't detect any decoupling capacitor either. Also connect pin5 (Control Voltage (CV)) via 10nF to ground.
Hans
Boncuk is offline
Old 27th August 2008, 03:13 PM   #14
Hi, i dont have any trouble retriggering the timer the prob is it triggers when switched on, which i want to get rid of.
EDDY99 is offline
Old 28th August 2008, 12:41 AM   #15
So why do you disconnect power then? Every timer circuit produces a short output pulse when energized.
Boncuk is offline
monostable, timer
Consider the Monostable..... UTMonkey General Electronics Chat 10 11th December 2007 08:40 PM
Astable and Monostable Eplanet General Electronics Chat 5 26th October 2007 11:01 PM
Digital Monostable elnaz General Electronics Chat 4 17th September 2004 07:49 PM
555 timer Monostable mode WilliamN General Electronics Chat 4 15th August 2004 04:36 AM
Help with 555/556 monostable timer circuit oldchap Electronic Projects Design/Ideas/Reviews 3 19th February 2004 06:48 PM
