Old 21st August 2008, 04:35 AM   #1
Question Resistors & 48V DC Question
Hello everyone, I'm new to the forum!
I am planning a project with LED lighting with DMX. The controller I'm wishing to use has an output of 48 volts DC and 4 amps on each channel.
Now, I only have knowledge in building LED circuits for 12V DC.
On some of the channels, I will want to connect a single LED and of course I'll need a resistor. However, at 48V, I'm wondering if I need a special resistor that can handle such voltage? I used an LED resistor calculator and it said I would need a resistor that could handle 22 Watts... thats a little too much. Those things are too big for my project.
Any help is appreciated! Thanks!
Altanore is offline
Old 21st August 2008, 05:04 AM   #2
Well, if you want to run more than one LED per output, then put the LEDs in series to save power. The other option to look at is running the "controller" at a lower voltage. Post a link to the "controller" so we can see if this is viable.
kchriste is offline
Old 21st August 2008, 05:29 AM   #3
Series the LED's is your best option. 20 red LED's yields 34 Volts, and R to drop down from 48V.
15 white LED's ± 45Volts and R to drop down excess and set LED current at about 15 to 20 mA.
If single LED on 48 Volts say 20 mA will yield a resistor of 2400R and 1 Watt.
I would go for 2700R or use 2 in series of 1500R to split the heat over the resistors.
Then multiply it out by the amount of LED's required.
Please don't sent me private messages, I will not answer them.
The questions asked can be discussed in the open forums.
http://www.youtube.com/user/RODALCO2007 some interesting electrical stuff to watch.
RODALCO is offline
Old 21st August 2008, 06:33 AM   #4
Thanks!
The controller in question is:
http://www.celestialaudio.com/ca_dmx_32_nfet/index.html
If something goes wrong, at least resistors don't blow up violently!
Mind you, LED's can...
Its just the heat that concerns me... is it bad if a resistor is still functioning but almost too hot to touch?
I still get that with resistors on 12v.
Altanore is offline
Old 21st August 2008, 12:11 PM   #5
I take it that this is a high power LED?
Build a switching regulator.
I'll post the circuit (which is very simple) if you're interested.
if I know the answer.
Hero999 is offline
Old 21st August 2008, 02:59 PM   #6
Originally Posted by Altanore View Post
. . .if a resistor is still functioning but almost too hot to touch?
An X watt resistor dissipating X watts is normally too hot to touch.
Willbe is offline
Old 21st August 2008, 07:36 PM   #7
I still don't understand why you're using 48VDC; is this going to be powered from a UPS or wind/solar powered installation?
Hero999 is offline
Old 21st August 2008, 07:57 PM   #8
In the link it says "up to 48v" which leads me to believe it'll go lower.
gerty
gerty is offline
Old 21st August 2008, 08:44 PM   #9
I agree. It sounds like the outputs are programmable/adjustable, depending on the number of LEDs in use. See if you can step it down.
"Remember, you're special.....just like everyone else."
rezer is offline
Old 22nd August 2008, 02:21 AM   #10
I have been in contact with them about the board. I just sent an e-mail asking if the voltage is adjustable. They do have another board that runs at 12V but each channel can only support 20MA.
I've decided that I will have to connect LED's in a series. Save money and I wont have to get heavy duty resistors :P.
It's just the very high power LED's (1-3 watt) that I will have problems with. I know there are LED drivers for these type of LED's but the only ones I have found can only handle an input up to 32V.
This project is for a computer case modification. The controller board will either be connected to the computer power supply or wall outlet... I'll probably have to make an external box for all the hardware.
Altanore is offline
Old 22nd August 2008, 02:49 AM   #11
Thanks!
Just set the LED power supply to the level you need. The lower the better. ie: If the longest, and the the highest voltage drop LED string, needs 8V, then make the LED supply 12V and burn the remaining 4V in a resistor. No need to supply it with 48V at all. All they mean is that is good UP to 48V if you needed it.
kchriste is offline
Old 22nd August 2008, 07:37 AM   #12
Oh.. i didn't seem to clue into that! Well that saves me from all the trouble then.
Thanks for the help everyone.
Altanore is offline
48v, question, resistors
Newbie Question about resistors,transistors? AaronOregon General Electronics Chat 20 22nd August 2008 01:59 PM
resistors heyhi General Electronics Chat 18 25th February 2008 05:54 PM
Meg ohm Resistors fingers General Electronics Chat 15 17th June 2007 03:59 PM
Resistors Decadence General Electronics Chat 14 29th May 2005 02:39 AM
Question about LEDs and resistors. tribaloverkill Electronic Projects Design/Ideas/Reviews 5 1st November 2004 05:55 AM
