Drive a motor? How big is the motor?
DEAR,
i want to build a rain detector.the circuit should as to drive a motor from the rain detector.If anyone has idea it will be appreciated.
Use a piezoelectric transducer as microphone and a vox circuit to drive a relay for your motor.
Abolish the deciBel !
Hi ctgroup,
the easiest way to make a rain detetector is making it from a small piece of PCB board. Check the screenshot please. The dimensions are 50X50mm with enough traces for a distinct change in resistance.
Connect the sensor to a comparator as shown in the screenshots, too.
The output swings from low to high if there is rain. To make it swing from high to low just connect the OpAmp by changing + and - input pins.
Hans
I spread chaos where ever I am. Too bad I can't be everywhere.
Good plan, only issue I see is if there is a lot of morning dew moisture that could build up and also activate the circuit.
acquiring knowledge is like doing a jig saw puzzle, many of the bits on their own dont make sense, but they are all needed to give a complete picture........... "Eric Gibbs"
www.geoepicenter.com
Many, many years ago I use to work for NOAA. We had these rain gauges that work as follows.
There was a small rectangular metal container balanced on a pivot. It was maybe 4 to 5cm long. Kinda like a little metal bucket. In normal situation the rain bucket sat level, but as it would rain, the bucket would fill and pivot. The pivot action would trigger a microswitch. You could use this concept to have the trigger drive a relay. Then again, if morning dew is not an issue, I would say boncuks idea is the way to go
One more thing. We sometimes had problems with bird poop triggering the gauge...lol
| Similar Threads | ||||
| Thread | Starter | Forum | Replies | Last Post |
| circuit diagram of a rain sensor and its explanation | kehinde | Electronic Projects Design/Ideas/Reviews | 19 | 9th January 2009, 03:02 PM |
| "tipping buckets" rain gauge | justDIY | Electronic Projects Design/Ideas/Reviews | 2 | 20th September 2008, 06:09 AM |
| Cheap(ish) rain sensor? | NJ Roadmap | General Electronics Chat | 57 | 23rd March 2007, 09:17 PM |
| electric fault detector & Underground cable theft detector | ADELRESTA | Electronic Projects Design/Ideas/Reviews | 8 | 12th June 2006, 01:06 PM |
| electronic rain gauge?? | jerfude | Electronic Projects Design/Ideas/Reviews | 4 | 21st January 2004, 06:08 AM |
