Old 14th August 2008, 12:16 PM   (permalink)
Default 5V to 12 V PWM
Hi
I am trying to design a very basic circuit which converts my 5 V PWM from my NI FPGA card to a 12 V PWM.So basically what I need is an amplifier circuit and also protection for my FPGA card from 12 V.
I am a Mechanical Engineer and I dont have much idea .Can anyone of you help me.
If a circuit is available in the market which can serve my purpose you can tell me what I should ask for.
mailtonsk is offline
Old 14th August 2008, 12:26 PM   (permalink)
Originally Posted by mailtonsk View Post
Hi
You require either a power transistor or MOSFET amplifier.
Do you have details of the current the motor requires thats driven by the PWM.?
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is online now
Old 14th August 2008, 02:14 PM   (permalink)
Default 5V to 12 V
thanx for the reply...
But I am actually using the circuit for a solenoid fuel injector which works with 12V square pulse.
So only thing I need to do is amplify my 5V PWM to a 12 V PWM.
Old 14th August 2008, 05:55 PM   (permalink)
I would assume that the solenoid is ground referenced so that you need a high side driver. i would also assume that the 5V pwm signal is coming from a microcontroller and you don't want much current pulled out of it.
how about tying the 5V pwm signal to the gate of a peanut NFET, say a 2N7000. The source is tied to common/ground and the drain is tied to a 10k resistor whose other end is tied to 12V. Maybe have a 10k resistor across the gate-source to make sure it is off if the cpu is not awake but 12V is. Connect the gate of a PFET (don't know a good one off hand - i don't use them too much - but it needs to handle current - may need a heatsink as well) to the drain of the NFET, the source to 12V and the drain to the solenoid.
OutToLunch is offline
Old 14th August 2008, 06:37 PM   (permalink)
thanks for the suggestion....
Let me try it out.....
I shall keep updating.......
