Old 13th August 2008, 02:46 PM   (permalink)
Unhappy Using C Coding
Hello everyone,
I'm plannin of doing a project tat can be controlled from a computer..To be more clear..Like i ve seen a guy who controlled a toy car using the arrow keys of a keyboard..When i asked him he said "i designed the circuit using IC's and then fitted it in the parallel port of my PC..I wrote a c coding.Then on executing the program i am able to control it"..Something similar to this..Basic hardware+a softwareAny ideas???
rag's is offline
Old 13th August 2008, 02:55 PM   (permalink)
Without knowing what you know and what you are trying to do no one can answer your question.
Try looking at the USB-Bitwacker (UBW) link in my signature. It shows how you can write Basic code on the PC to control a PIC that controlls your project.
Originally Posted by rag's View Post
Hello everyone,
I'm plannin of doing a project tat can be controlled from a computer..To be more clear..It must ve a coding part in a software-particularly C..n by interfacing the hardware to the computer one must be able to operate the hardware using the software coding done..Any ideas???
3v0 is offline
Old 13th August 2008, 03:01 PM   (permalink)
Not PIC an all...Like i ve seen a guy who controlled a toy car using the arrow keys of a keyboard..When i asked him he said "i designed the circuit using IC's and then fitted it in the parallel port of my PC..I wrote a c coding.Then on executing the program i am able to control it"..Something similar to this..Basic hardware+a software
rag's is offline
Old 14th August 2008, 02:34 PM   (permalink)
Your original post did not say anything about using the printer port, it is bad form to edit it after the fact. OK to add info, not to change the flavor of the question/post.
Try googling for the info you need. I know P H Anderson has some info on it.
Some is free others not.
Why not use USB and a PIC? The printer cable will be a bear to drag around.
What exactly do you want the car to do. Do you need to reverse the car. Do you need proportional control. Do you know what an H-Bridge is ?
I have no idea what you are capable of or if the project is too complex for your skill set. This is often the case.
3v0 is offline
Old 18th August 2008, 06:47 AM   (permalink)
thnx 4 d info..ill check out d site
rag's is offline
Old 18th August 2008, 09:44 AM   (permalink)
Some years back we did an exact project like that.... and I used no microcontrollers in it. No PIC no AVR.
We used UM95089 DTMF generator on the transmitter side. Our Sw on the PC wrote controll words on the parallel port. The 95089 chip conneted there converted it to a DTMF tone which we 'aired' using a FM transmitter.
On the receiver, we had a FM receiver that received the tone, converted it back to that digital word using the chip UM8870. That word served as input to the H-Bridges that finally controlled the motors.
95089 can be hard to find.
Its not the Practice that makes a man perfect. Its the Man who makes the practice perfect
----- Pradeep K. Shima -----
pkshima is offline
need help with coding Iceman96 Electronic Projects Design/Ideas/Reviews 3 21st April 2008 12:07 AM
RLF Coding Problem Suraj143 Micro Controllers 10 7th August 2007 04:58 AM
PIC IR coding timothyjackson Micro Controllers 18 28th August 2005 01:56 PM
help on C coding Emantra Electronic Projects Design/Ideas/Reviews 7 26th July 2005 09:45 AM
Frustrating PIC coding asmpic Micro Controllers 14 13th November 2004 07:25 AM
