Old 9th August 2008, 05:10 PM   (permalink)
When voltage drops to 4.8 (as suggested), then blinking LED will blink. I was informed that the batteries would start at 6vdc and then normally operate at 4 vdc. I have not done my research to comfirm this. I am not sure if LM139 is the way I want to go. There is alot of unused gates.(room, power, and size are issues) Am I getting closer with this...?
b_reagle is offline
Old 9th August 2008, 05:21 PM   (permalink)
Whoops, I mean like this:
b_reagle is offline
Old 9th August 2008, 10:58 PM   (permalink)
Originally Posted by Roff View Post
If he does the things that I have highlighted in red, the LED will be on until the voltage drops below Vref. I don't think that's what he wants. Of course, he really wants a flasher anyway, so an LED on the comparator output ain't gonna work anyway.
Oops, your right. Now that is just embarrassing
Pay it forward.
Mikebits is online now
Old 10th August 2008, 12:57 AM   (permalink)
What about like this?
b_reagle is offline
Old 10th August 2008, 01:23 AM   (permalink)
After my last blunder, I am somewhat afraid to give out advice, but just one comment.
For U1, from the part number you listed, the device has an open drain output which means it needs a pull up and is an active low out.
Pay it forward.
Old 10th August 2008, 01:57 AM   (permalink)
Then would this be correct? or closer? or just plain wrong?
b_reagle is offline
Old 10th August 2008, 02:31 AM   (permalink)
That would work, but this way is simpler and uses WAY less idle current. I have kept the resistor in series with the LED in case you will be using a regular LED, but flashing LEDs usually don't need a resistor:
kchriste is offline
Old 10th August 2008, 02:44 AM   (permalink)
Thanks for the help kchriste. Is this the simpliest(cheapest) way of doing this?
b_reagle is offline
Old 10th August 2008, 02:46 AM   (permalink)
Roff's right (say that three times after two martinis).
Attachment after Paisley
All those who believe in psycho kinesis, raise my hand.
AllVol is offline
Old 10th August 2008, 02:55 AM   (permalink)
Did you read the follow on post, or just rubbing it in...
Pay it forward.
Old 10th August 2008, 03:02 AM   (permalink)
So Allvot, you say use a comparator instead of voltage reglator, or are you really just rubbing it in.LOL.
b_reagle is offline
Old 10th August 2008, 03:14 AM   (permalink)
Not to rub it in, but you mean voltage detector right?
Kchriste latest plan looks the way to go IMHO.
I am going to crawl back underneath my keyboard now
Pay it forward.
Old 10th August 2008, 03:19 AM   (permalink)
Right voltage detector. Thanks again for your help.
b_reagle is offline
Old 10th August 2008, 03:29 AM   (permalink)
It is the simplest, but not necessarily the cheapest if you have zeners and opamps in your junk box. If you need to buy the parts anyway, then my way will work out the best for you. The problem with the opamp/zener route, is that you'll have a higher current draw off the batteries and they won't last as long. Those low voltage detector circuits draw less than 3uA and you'll be hard pressed to build anything with opamps and zeners that draws less than 1000uA.
kchriste is offline
Old 10th August 2008, 03:33 AM   (permalink)
Good. That is a very cool part indeed. I never knew they existed. Now on the the next puzzle... Thanks again.
b_reagle is offline
Voltage ramp circuit Gordon McLeod Electronic Projects Design/Ideas/Reviews 1 15th June 2008 06:52 PM
Voltage Stepping Circuit fantasymick Electronic Projects Design/Ideas/Reviews 3 30th May 2008 05:02 AM
how do I reduce the voltage in a circuit? doitmyselfer0523 General Electronics Chat 5 5th February 2008 05:20 PM
Voltage Protection Circuit jnnewton Electronic Projects Design/Ideas/Reviews 15 20th January 2008 11:02 AM
6vdc - 3vdc Converter Circuit randyv Electronic Projects Design/Ideas/Reviews 7 16th October 2004 03:51 PM
