I never got a chance to build mine, ordered the parts just didn't have the time to put it all together. Will do when I get the chance though.
Well I don't mean to sound cocky but you can do it with one transistor, 1 resistor and 1 pot;
This is a constant-current dummy load, adjustable with the pot from 0A to about 1A, depending if you use 3.9 ohm or 4.7 ohm for Rload.Code:+12v ------>|-------, (unreg) LED | | | +5v --------, | | | | | NPN (or Darl) 500 ohm R C TIP122 etc pot R<----B R E | | | | | Rload 4.7 ohms 5w | | (etc) | | Gnd ---------*-------*--
It will drift 1 or 2 percent as the transistor warms up, which is rarely an issue.
I would use a switching regulator for this, it seems silly to buy expensive efficient LEDs, then waste a load of power in a linear regulator.
Please ask on the open forum if you have a question and I'll be happy to help, if I know the answer.
