| Hi, can some experience help me with this very problem i am facing. i am trying to write a source code to generate a 200ms pulse at various interval, let say.. 5s, 50, 100..... using PIC16F887. I used the AD converter becos i wanted to use a rotary switch to control the frequency or speed. i have only few days to make this work. i need to used this switch to drive a relay. Can someone help me look at this code and the errors in it or better still help me debug or edit it. i have tried wit could not build. at an instance it did build when i started the program with org 0x2100. but the Led did not light. i wanted to use the led to monitor the pulse time. I tried to debug the code and i always recieve error CORE-E0002: Stack under flow error occurred from instruction at 0x000005 Thank you Code: list p=16f887 ; list directive to define processor
#include <p16f887.inc> ; processor specific variable definitions
; '__CONFIG' directive is used to embed configuration data within .asm file.
; The labels following the directive are located in the respective .inc file.
; See respective data sheet for additional information on configuration word.
__CONFIG _CONFIG1, _LVP_OFF & _FCMEN_ON & _IESO_OFF & _BOR_OFF & _CPD_OFF & _CP_OFF & _MCLRE_ON & _PWRTE_ON & _WDT_OFF & _INTRC_OSC_NOCLKOUT
__CONFIG _CONFIG2, _WRT_OFF & _BOR21V
; variable decleration
cblock 0x00
Delay1 ; Assign an address to label Delay1
Delay2
Display ; define a variable to hold the diplay
timer1
incf_count
Endc
org 0x0021 ; Start program at address
count equ 0x20 ; Counter variable
nop ; required for debugger
; Initialize PORT D to be all outputs and PORT A all inputs.
Start
BANKSEL PORTD
CLRF PORTD
BANKSEL TRISD
movwf TRISA ; Make PortA all input
clrf TRISD ; Set PORTD for output
clrf PORTD ; write 0s to PORTD
clrf count ; Initialize count to 0.
; Setup timer 1
bcf T1CON,TMR1ON ; Turn Timer 1 off.
bsf T1CON,T1CKPS1 ; Set prescaler for divide bsf T1CON,T1CKPS0 by 8.
bcf T1CON,T1OSCEN ; Disable the RC oscillator.
bcf T1CON,TMR1CS ; Use the Fosc/4 source.
clrf TMR1L ; Start timer at 0000h
clrf TMR1H ; clear the pre-scalar counter
bsf T1CON,TMR1ON ; Start the time
Time1 btfss PIR1,TMR1IF ; Did timer overflow?
; Timer overflowed, increment counter and display
bcf PIR1,0 ; Clear the flag
incf count,F ; Bump the counter
movf count,W ; Get the count
movwf PORTD ; Send to Port D.
bcf T1CON,0 ; Turn the timer off.
movlw 80h ; Start timer at 80h
movwf TMR1H
clrf TMR1L
bsf T1CON,0 ; Turn the timer on.
movlw 0xFF
movlw 0x00 ; Left Justified, Vdd-Vss referenced
movwf ADCON1
BANKSEL TRISA
movlw 0xFF ; we want all Port A pins Analog
movwf ANSEL
bcf STATUS,RP0 ; back to Register Bank 0
movlw 0x41
movwf ADCON0 ; configure A2D for Fosc/8, Channel 0 (RA0), and turn on the A2D module
nop ; wait 5uS for A2D amp to settle and capacitor to charge.
nop ; wait 1uS
nop ; wait 1uS
nop ; wait 1uS
nop ; wait 1uS
bsf ADCON0,GO_DONE ; start conversion
btfss ADCON0,GO_DONE ; this bit will change to zero when the conversion is complete
goto $-1
movf ADRESH, W ; Copy the display to the LEDs
movwf PORTD
goto timer1
End ; directive 'end of program' | |
| I have adjusted the code and this is what i got. i built the program again. and it runed. but when program it to my pic. the leds did not blink as expected. when i try to debug the code by puting a breakpoint. i recieve this following massage no matter where the break point is placed. CORE-E0002: Stack under flow error occurred from instruction at 0x000005 CORE-E0002: Stack under flow error occurred from instruction at 0x000005 CORE-E0002: Stack under flow error occurred from instruction at 0x000005 Wat does this mean and how can i go about it? list p=16f887 ; list directive to define processor #include <p16f887.inc> ; processor specific variable definitions ; '__CONFIG' directive is used to embed configuration data within .asm file. ; The labels following the directive are located in the respective .inc file. ; See respective data sheet for additional information on configuration word. __CONFIG _CONFIG1, _LVP_OFF & _FCMEN_ON & _IESO_OFF & _BOR_OFF & _CPD_OFF & _CP_OFF & _MCLRE_ON & _PWRTE_ON & _WDT_OFF & _INTRC_OSC_NOCLKOUT __CONFIG _CONFIG2, _WRT_OFF & _BOR21V ; variable decleration cblock 0x00 Delay1 ; Assign an address to label Delay1 Delay2 Display ; define a variable to hold the diplay timer1 incf_count Endc org 0x0020 ; Start program at address count equ 0x20 ; Counter variable nop ; required for debugger ; Initialize PORT D to be all outputs and PORT A all inputs. Start BANKSEL PORTD CLRF PORTD BANKSEL TRISD movwf TRISA ; Make PortA all input clrf TRISD ; Set PORTD for output clrf PORTD ; write 0s to PORTD clrf count ; Initialize count to 0. ; Setup timer 1 bcf T1CON,TMR1ON ; Turn Timer 1 off. bsf T1CON,T1CKPS1 ; Set prescaler for divide bsf T1CON,T1CKPS0 by 8. bcf T1CON,T1OSCEN ; Disable the RC oscillator. bcf T1CON,TMR1CS ; Use the Fosc/4 source. clrf TMR1L ; Start timer at 0000h clrf TMR1H ; clear the pre-scalar counter bsf T1CON,TMR1ON ; Start the time Time1 btfss PIR1,TMR1IF ; Did timer overflow? ; Timer overflowed, increment counter and display bcf PIR1,0 ; Clear the flag incf count,F ; Bump the counter movf count,W ; Get the count movwf PORTD ; Send to Port D. bcf T1CON,0 ; Turn the timer off. movlw 80h ; Start timer at 80h movwf TMR1H clrf TMR1L bsf T1CON,0 ; Turn the timer on. movlw 0xFF movlw 0x00 ; Left Justified, Vdd-Vss referenced movwf ADCON1 BANKSEL TRISA movlw 0xFF ; we want all Port A pins Analog movwf ANSEL bcf STATUS,RP0 ; back to Register Bank 0 movlw 0x41 movwf ADCON0 ; configure A2D for Fosc/8, Channel 0 (RA0), and turn on the A2D module nop ; wait 5uS for A2D amp to settle and capacitor to charge. nop ; wait 1uS nop ; wait 1uS nop ; wait 1uS nop ; wait 1uS bsf ADCON0,GO_DONE ; start conversion btfss ADCON0,GO_DONE ; this bit will change to zero when the conversion is complete goto $-1 movf ADRESH, W ; Copy the display to the LEDs movwf PORTD goto timer1 End ; directive 'end of program' | |
| Change the line, Code: org 0x0020 ; Start program at address Code: org 0x0000 ; Start program at address Mike. | |
| See your other thread. Let us know if that doesn't fix it. Mike. | |
| WHAT ORDER THREAD. ARE U SAYING IT MIGHT BE FROM THE ORDER OM CODE. The code is supposed to start with org 0x000. what do you thinlk. i tried it is even worse, could not build. | |
One reason why you had problems there was an equate at 0x20 , after the origin, also added 0x0004 for intr vector It now assembles in MPLAB IDE ... OK.. list p=16f887 ; list directive to define processor #include <p16f887.inc> ; processor specific variable definitions Code: ; '__CONFIG' directive is used to embed configuration data within .asm file.
errorlevel -302, -207
cblock 0x00
Delay2
timer1
incf_count
Endc
goto Start
org 0x0004
retfie
Start
BANKSEL PORTD
CLRF PORTD
BANKSEL TRISD
; Setup timer 1
movwf TMR1H
clrf TMR1L
movlw 0xFF
movwf ADCON1
BANKSEL TRISA
movwf ANSEL
movlw 0x41
nop ; wait 1uS
nop ; wait 1uS
nop ; wait 1uS
nop ; wait 1uS
goto $-1
movwf PORTD
goto timer1
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 7th August 2008 at 03:33 PM. | ||
| Hi Eric, Thanks for you time please the program did not compile on my MPLAB IDE. Built failed. this was the result. did you try it? | |
Yes I did Build it with MPLAB,, I will retry OK.
Redone with MPLAB OK. See clip from MPLAB output.
| Hi, What version of MPLAB are u using. I am using MPLAB IDE v8.00. Look at the output i am getting from my MPLAB HTML Code: Clean: Deleting intermediary and output files. Clean: Deleted file "C:\Program Files\Microchip\MPASM Suite\Template\Object\16F887TMPO.o". Clean: Deleted file "C:\Program Files\Microchip\MPASM Suite\Template\Object\16F887TMPO.lst". Clean: Done. Executing: "C:\Program Files\Microchip\MPASM Suite\MPAsmWin.exe" /q /p16F887 "16F887TMPO.ASM" /l"16F887TMPO.lst" /e"16F887TMPO.err" /o"16F887TMPO.o" Warning[203] C:\PROGRAM FILES\MICROCHIP\MPASM SUITE\TEMPLATE\OBJECT\16F887TMPO.ASM 66 : Found opcode in column 1. (goto) Message[302] C:\PROGRAM FILES\MICROCHIP\MPASM SUITE\TEMPLATE\OBJECT\16F887TMPO.ASM 77 : Register in operand not in bank 0. Ensure that bank bits are correct. Message[302] C:\PROGRAM FILES\MICROCHIP\MPASM SUITE\TEMPLATE\OBJECT\16F887TMPO.ASM 78 : Register in operand not in bank 0. Ensure that bank bits are correct. Message[302] C:\PROGRAM FILES\MICROCHIP\MPASM SUITE\TEMPLATE\OBJECT\16F887TMPO.ASM 108 : Register in operand not in bank 0. Ensure that bank bits are correct. Message[302] C:\PROGRAM FILES\MICROCHIP\MPASM SUITE\TEMPLATE\OBJECT\16F887TMPO.ASM 111 : Register in operand not in bank 0. Ensure that bank bits are correct. Executing: "C:\Program Files\Microchip\MPASM Suite\MPLink.exe" "C:\Program Files\Microchip\MPASM Suite\LKR\16f887.lkr" "C:\Program Files\Microchip\MPASM Suite\Template\Object\16F887TMPO.o" /o"16F887TMPO.ASM.cof" /M"16F887TMPO.ASM.map" /W MPLINK 4.14, Linker Copyright (c) 2007 Microchip Technology Inc. Error - section '.org_1' can not fit the absolute section. Section '.org_1' start=0x00000004, length=0x00000062 Errors : 1 Link step failed. BUILD FAILED: Fri Aug 08 09:06:42 2008 Code: ;****************************************************************************************************************************
; This file is a source code used for switching. this code will generate an approximately 0.2s pulse at various interval *
; to drive a relay. *
; Refer to the MPASM User's Guide for additional information on features of the assembler and linker (Document DS33014). *
; Refer to the respective PIC data sheet for additional information on the instruction set. *
; Filename: 16F887TMPO.asm *
; Date:04/08/2008 *
; File Version: *
; Author: Jonathan Okocha *
; Company: Kelman *
; Files required: *
; Notes:I was able to get a 209ms pulse, using a 10MHZ crystal This is very close to the desired 200ms. *
; length of an instruction @ 10MHz = 1/(10MHZ/4) = 0.4µs = T *
; periodic length of the timer1 Tp = T x 65536 x 8 = 0.209s = 209ms (using a *
; prescaler of (1:8) 11, 16-bit Prescaler *
; In the interrupt service routine: >> every time the interrupt fires: ++count; >> after 25 *
; times > 5s, after 50 times 10s and so on *
; But please mind that these times are not really 100% exact because the crystal is not exact *
; and some interferences are also always present. For exact timing an RTC will be connected *
cblock 0x00
Delay2
timer1
incf_count
Endc
goto main
org 0x0004
retfie
main
BANKSEL PORTD
CLRF PORTD
BANKSEL TRISD
; Setup timer 1
Timer1 btfss PIR1,TMR1IF ; Did timer overflow?
movwf TMR1H
clrf TMR1L
movlw 0xFF
movwf ADCON1
BANKSEL TRISA
movwf ANSEL
movlw 0x41
nop ; wait 1uS
nop ; wait 1uS
nop ; wait 1uS
nop ; wait 1uS
goto $-1
movwf PORTD
goto timer1
End ; directive 'end of program' what i did was to build from my template code, after deleting everyword or code. why is this happenning top me now? what do i do next? will appreciate any help. Thanks for the help so far | |
| The code above is written as absolute code and should not have a linker script. If you remove the linker file from your project it will assemble fine. One other thing, you shouldn't change the template files, you should copy (and rename) them to another location before including them in your project. Somewhere like My Documents/Projects. Mike. | |
| BTW, if you want to use a linker script you need to change your code to be, Code: ;**************************************************************************************************************************** ; * ; Filename: 16F887TMPO.asm * ; Date:04/08/2008 * ; File Version: * ; * ; Author: Jonathan Okocha * ; Company: Kelman * ; * ; * ;**************************************************************************************************************************** ; * ; Files required: * ; * ; * ;**************************************************************************************************************************** ; * ; Notes:I was able to get a 209ms pulse, using a 10MHZ crystal This is very close to the desired 200ms. * ; * ; length of an instruction @ 10MHz = 1/(10MHZ/4) = 0.4µs = T * ; * ; periodic length of the timer1 Tp = T x 65536 x 8 = 0.209s = 209ms (using a * ; * ; prescaler of (1:8) 11, 16-bit Prescaler * ; * ; In the interrupt service routine: >> every time the interrupt fires: ++count; >> after 25 * ; * ; times > 5s, after 50 times 10s and so on * ; * ; But please mind that these times are not really 100% exact because the crystal is not exact * ; and some interferences are also always present. For exact timing an RTC will be connected * ; * ;**************************************************************************************************************************** list p=16f887 ; list directive to define processor #include <p16f887.inc> ; processor specific variable definitions ; '__CONFIG' directive is used to embed configuration data within .asm file. ; The labels following the directive are located in the respective .inc file. ; See respective data sheet for additional information on configuration word. __config _CONFIG1, _LVP_OFF & _FCMEN_ON & _IESO_OFF & _BOR_OFF & _CPD_OFF & _CP_OFF & _MCLRE_ON & _PWRTE_ON & _WDT_OFF & _INTRC_OSC_NOCLKOUT __config _CONFIG2, _WRT_OFF & _BOR21V ; variable decleration udata Delay1 res 1 ; Assign an address to label Delay1 Delay2 res 1 Display res 1 ; define a variable to hold the diplay timer1 res 1 incf_count res 1 count equ 0x20 ; Counter variable Reset code 0x0000 ; Start program at address goto main IRQ code 0x0004 retfie code ; Initialize PORT D to be all outputs and PORT A all inputs. main banksel PORTD clrf PORTD banksel TRISD movwf TRISA ; Make PortA all input clrf TRISD ; Set PORTD for output clrf PORTD ; write 0s to PORTD clrf count ; Initialize count to 0. ; Setup timer 1 bcf T1CON,TMR1ON ; Turn Timer 1 off. bsf T1CON,T1CKPS1 ; Set prescaler for divide bsf T1CON,T1CKPS0 by 8. bcf T1CON,T1OSCEN ; Disable the RC oscillator. bcf T1CON,TMR1CS ; Use the Fosc/4 source. clrf TMR1L ; Start timer at 0000h clrf TMR1H ; clear the pre-scalar counter bsf T1CON,TMR1ON ; Start the time Timer1 btfss PIR1,TMR1IF ; Did timer overflow? ; Timer overflowed, increment counter and display bcf PIR1,0 ; Clear the flag incf count,F ; Bump the counter movf count,W ; Get the count movwf PORTD ; Send to Port D. bcf T1CON,0 ; Turn the timer off. movlw 80h ; Start timer at 80h movwf TMR1H clrf TMR1L bsf T1CON,0 ; Turn the timer on. movlw 0xFF movlw 0x00 ; Left Justified, Vdd-Vss referenced movwf ADCON1 banksel TRISA movlw 0xFF ; we want all Port A pins Analog movwf ANSEL bcf STATUS,RP0 ; back to Register Bank 0 movlw 0x41 movwf ADCON0 ; configure A2D for Fosc/8, Channel 0 (RA0), and turn on the A2D module nop ; wait 5uS for A2D amp to settle and capacitor to charge. nop ; wait 1uS nop ; wait 1uS nop ; wait 1uS nop ; wait 1uS bsf ADCON0,GO_DONE ; start conversion btfss ADCON0,GO_DONE ; this bit will change to zero when the conversion is complete goto $-1 movf ADRESH,W ; Copy the display to the LEDs movwf PORTD goto timer1 end ; directive 'end of program' Mike. | |
As Mike explains, no linker required. What about the other thread, please close one, its confusing.
| Thanks very much. the code is now running well. one very problem i am facing now is the result. i wanted a 200ms pulse at various interval..ie.. 5s..50s..100s..200s to drive a relay. off course i wan it to be a digital output. i wanted to controlled the speed or frequency by an analogue input from a rotary switch. can you look at the code? where am i wrong? Code: list p=16f887 ; list directive to define processor
udata
Delay2 res 1
timer1 res 1
incf_count res 1
goto main
IRQ code 0x0004
retfie
code
main
BANKSEL TRISD
BANKSEL PORTD
; Setup timer 1
movwf TMR1H
clrf TMR1L
movlw 0xFF
movwf ADCON1
BANKSEL TRISA
movlw B'11111111' ; Left Justified, Vdd-Vss referenced
movwf ANSEL
movlw 0x41
nop ; wait 1uS
nop ; wait 1uS
nop ; wait 1uS
nop ; wait 1uS
goto $-1
movwf PORTD
goto timer1
end ; directive 'end of program' | |
| Pic16f887 | speakerguy79 | Micro Controllers | 6 | 8th August 2008 02:33 PM |
| EEPROM of PIC16F887.. | asp1987 | Micro Controllers | 13 | 28th May 2008 09:21 PM |
| pic16f887 analogue reference | spuffock | Micro Controllers | 5 | 15th October 2007 05:19 PM |
| Recommend PIC16F887 | falleafd | Micro Controllers | 4 | 24th June 2007 10:57 AM |
