The last time I posted a question I was spanked pretty hard I guess my imagination greatly exceeds my electronic knowledge And possibly the ability of electronics all together Anyway a few years ago I built a wimshurst machine it works Very well. I would like to copy its power output with a solid state device. From what I have read and this is a rough guess its power output is Around 150,000v somewhere in the high Hz to low kHz range and Extremely low currant I have a NST 1500v @ .60ma. I thought of building a 10-stage voltage multiplier witch would give Me my voltage but as was pointed out it would give me more currants Than I would need. And still need to raise freq. Any help with this problem or a completely new idea would be completely appreciated wjyates | |
A Wimshurst Machne puts out a DC current. The are some AC components when it arcs but the source is DC. Thus a voltage multiplier which generates DC would work in theory. Of course 10 stages requires that each stage have diode(s) capable of blocking 1500V. You generally need to add high value resistors across each stage to balance the voltage, otherwise one stage is likely to breakdown. A voltage multiplier reduces the available output current by approximately the number of stages so the output of the 10 stages will be 0.06ma or less.
__________________ Carl Curmudgeon Elektroniker | |
| http://www.electricstuff.co.uk/marxgen.htm Saw this a while back, thought it was pretty cool. Similar to what you are looking for. | |
| charm, times |
| Adding 8 Times a 10bit Number | Suraj143 | Micro Controllers | 11 | 21st February 2008 05:32 AM |
| alternating flasher with variable on times for each led | savarin | Electronic Projects Design/Ideas/Reviews | 16 | 13th December 2007 06:15 PM |
| HT9200A somes times dials ...sometimes does not dial...? | prevravanth | Micro Controllers | 0 | 5th July 2007 03:06 PM |
| PCB photo-resist exposure times? Mine won't develop! | HandyMan | Electronic Projects Design/Ideas/Reviews | 8 | 22nd February 2005 05:18 PM |
| Why do we use .63 as the times the toatal voltage change... | helpmeplz | Electronic Projects Design/Ideas/Reviews | 7 | 14th March 2003 12:25 AM |
