| Hi! I am trying to send some data to PIC18F87J50 via EUSART and then transimnit the data to computer via USB. The USB program I am using is Microchip USB firmware framework v2.2 USB keyboard prgram. and I write the EUSART function myself. The two EUSART function is pasted below. I put EUSART_config_1() function in the main function before the while(1) loop and put the receiving_1() in the keyboard() function within the if condition if(!HIDTxHandleBusy(lastTransmission)) so that if the received data is what I want I will transmit the data to computer like pressing a key. However the problem I am facing is that the EUSART seems cannot receive any data even I tried to continously receive 50 times. Could any one tell me what step I need to add to implement the feature? unsigned char receiving_1(void) { unsigned char tempx = 0; //PIE1bits.RC1IE = 1; //enable interrupts RCSTA1bits.SPEN = 1; // serial port enable RCSTA1bits.SREN = 1; // serial port enable RCSTA1bits.CREN = 1; // enable receiver BAUDCON1bits.RCIDL = 1; // receiving operation is active while(!PIR1bits.RC1IF) {} tempx = RCREG1; BAUDCON1bits.RCIDL = 0; // receiving operation is idle RCSTA1bits.SPEN = 0; // serial port disable RCSTA1bits.SREN = 0; // serial port enable RCSTA1bits.CREN = 0; // disable receiver //PIE1bits.RC1IE = 0; //disable interrupts return tempx; } void EUSART_config_1(void) { TRISC |= 0b10000000; //TRISG |= 0b00000100; // RCSTA1bits.SPEN = 1; //RCSTA2bits.SPEN = 1; TXSTA1 = 0b00000100; //bit7_CSRC: don't care //bit6_TX9: selects 8-bit transmission //bit5_TXEN: transmit disable //bit4_SYNC: Asynchronous mode //bit3_SENDB: Sync Break transmission complete //bit2_BRGH: high speed //bit1_TRMT*: TSR full //bit0_TX9D: disable 9th bit transmist data RCSTA1 = 0b00000000; //bit7_SPEN: serial port disabled //bit6_RX9: selects 8-bit reception //bit5_SREN: don't care //bit4_CREN: disable reveiver //bit3_ADDEN: disables address detection //bit2_FERR*: no framing error //bit1_OERR*: overrun error //bit0_RX8D: disable 9th bit of received data(useless) BAUDCON1 = 0b00010000;//bit7_ABDOVF: no BRG rollover has occurred //bit6_RCIDL*: receieve operation is idle //bit5_DTRXP: receive data is not inverted //bit4_SCKP:idle state for transmit is a low level //bit3_BRG16: 8-bit baud rate generator-SPBRG1 only //bit2: unimplemented //bit1_WUE: RX1 pin is not monitored or rsing edge detected //bit0_ABDEN: baud rate measurement disabled or completed SPBRG1 = 77; //baud rate set to 9600 for 12MHz, high speed } | |
| Power Transmission | ebuka_2 | Electronic Projects Design/Ideas/Reviews | 9 | 13th May 2008 05:10 PM |
| PIC 18f1220 EUSART Baud Rate Cache Problem | wklose99 | Micro Controllers | 7 | 16th April 2008 11:37 PM |
| EUSART issues | richb | Micro Controllers | 3 | 21st March 2008 03:26 AM |
| IR transmission | mayassn | General Electronics Chat | 3 | 14th February 2008 02:56 AM |
| RF Transmission | Hicks_Man | General Electronics Chat | 4 | 4th March 2006 08:59 PM |
