| Hi dear friends, I need to know about the lasers and their components to manufacture and principle in making Lasers.. Can anyone help out? Response will be gladly appreciated, | |
I Googled Laser Circuits there is a lot of info out there. http://www.discovercircuits.com/L/laser.htm http://www.discovercircuits.com/L/laser2.htm
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 6th August 2008 at 07:53 AM. | ||
| Thank u buddy.. | |
| What colour laser are you wanting to know about? Just quickly, here is a brief description on them Red lasers: Red lasers are very simple to make, they consist of basically a junction called a "Die", which when you pass power through, creates coherent light. It is a very simple and inexensive proccess , thats why you can get cheap 1mw reds for $1! Green, Blue, some yellow's/reds: These lasers use a much more complicated method. There is no single diode capable of producing these colours directly, so they have to be made using crystals with special coatings. It starts of with a high powered infrared diode ( Same kind of thing as the red diode, just emits IR light instead ). The IR diode shoots light into the fist crystal, for a green laser, this crystal converts the 808nm light into around 1064nm. The light is then passed through another crystal, which then converts the 1064nm light to around 532nm, which is green. THe process is similar for Blue lasers. THis is called a "DPSS" ( diode pumped solid state ) laser. Yellow can be made by combining red and green, and usually red is made from a diode directly, but yellow and red lasers can be made using the same kind of technique, though they usually cost alot more. There is a Blu-ray diode out there that is a diode, but the name is covering up the fact that the light is 405nm ( High UV ). Blu-ray sounds better than UV-ray right? There are a heap of sites with all the info on lasers.
__________________ The 3 laws of science.... 1. If it smells bad, It's chemistry. 2. If it's mushy, It's biology. 3. If it doesn't work, It's physics. www.laserpointerforums.com A forum for disscusion of lasers and laser shows! www.laserchat.org IRC chat for laser and electronic related stuff. | |
| I need the basic circuit to design high end laser.. Please can anyone help me out? | |
| Ok here is my requirement: I need to catch the laser beam at a distance thro reciever.. This is my requirement and how to design a laser of that type and may be the distance is 3-4 kms. | |
| There is no "Circuit" for a laser. Lasers are mostly mechanically made. Unless you have a lab with crystal coating facilities, the ability to work at microscopic sizes, a VERY steady hand and alot of time, its NOT a simple task. EDIT: So you just need a laser that can keep a tight beam at about 4km?
__________________ The 3 laws of science.... 1. If it smells bad, It's chemistry. 2. If it's mushy, It's biology. 3. If it doesn't work, It's physics. www.laserpointerforums.com A forum for disscusion of lasers and laser shows! www.laserchat.org IRC chat for laser and electronic related stuff. Last edited by things; 6th August 2008 at 08:15 AM. | |
A pulsed solid state lasing diode will easily have that range, ie 4Km. Are using a prism reflector at the far end or a receiver.? Whats the purpose of this laser.?
| What actually my project is to level the ground by using laser (Transmitter and Reciever).. I will give u the link if u want to get the basic idea.. http://dswcpunjab.gov.in/contents/Laser_Leveling.htm | |
| Thanks for ur responses dear friends.. iam greatfull to u all. | |
| Most lasers should be able to keep a reasonable beam over 4km. If your in doubt, get a laser with adjustable focus, that way you can focus it to your needs
For that application I would suggest a continous visible laser, Red is a popular choice. As you are 'levelling' a very narrow beam would be my choice, use a prism at at the receiving end, so the sending operator can see the returned beam.
http://www.electro-tech-online.com/e...-detector.html I gave you a link back then that I thought would be helpful to you. http://innovexpo.itee.uq.edu.au/2002...046/thesis.pdf Can you please explain why this was not what you want? Not to sound scolding or anything, but we covered this and then you vanished for awhile. What exactly is your goal? Do you just wish to duplicate the setup as shown in your link above? Again read the link I provided, it is a nice presentation on the subject.
__________________ Forget injuries, never forget kindnesses. Last edited by Mikebits; 6th August 2008 at 10:52 AM. | ||
| Oh ho what exactly i want is the proto type of the above project.. Can u briefly give a prototype for my project.? @Mikebits Ur project details thesis is different one. I hope u can bear me for a while.. Ok Sorry for my repeated topics.. | |
| Laser Help! | LiquidOrb24 | General Electronics Chat | 12 | 31st July 2007 10:50 PM |
| Laser | GatorGuy | General Electronics Chat | 20 | 20th June 2005 05:36 PM |
| Laser Tag. | jpalomba | Electronic Projects Design/Ideas/Reviews | 13 | 20th June 2004 06:29 AM |
| Laser Tag | Wasabi | Electronic Projects Design/Ideas/Reviews | 2 | 19th June 2004 01:54 PM |
| I need a laser | edisonboy | Electronic Projects Design/Ideas/Reviews | 3 | 22nd January 2004 06:10 PM |
