Old 6th August 2008, 06:45 AM   (permalink)
Default Running a pump at less power....
Hey, I am trying to convert my fog machine to a "fazer". The machine ATM uses a 240V piston type pump to get the juice from the container to the heater block. I know how real hazers work, and I know it wont be the same thing, but fazers are quite affective too. What i'm wondering, is if there is a way I can adjust how much juice gets to the heater. I cant use a valve, since its a pressure pump. I was thinking there had to be a way I could maybe slow the pump down abit. I dont think PWM would work, since you need 240V for the pump, and it runs on the 50hz frequency causing it to actually pump. I'm not sure voltage regulation would do it either, since its the frequency that determins how much/fast it pumps.
Any idea's?
The 3 laws of science....
1. If it smells bad, It's chemistry.
2. If it's mushy, It's biology.
3. If it doesn't work, It's physics.
www.laserpointerforums.com A forum for disscusion of lasers and laser shows!
www.laserchat.org IRC chat for laser and electronic related stuff.
things is offline
Old 6th August 2008, 07:48 AM   (permalink)
Can you use a mechanical solution rather than an electronic on?
Why not have a bypass valve which connects the output of the pump back to the input or back to the supply tank.
When the bypass valve is closed, the pump is delivering full output.
When the bypass valve is open, the pump delivers a much reduced output.
JimB is offline
Old 6th August 2008, 07:52 AM   (permalink)
I need to be able to remotely control it. Apparently you can vary the voltage, but they "Chatter". Anyone know what that is?
things is offline
Old 6th August 2008, 08:01 AM   (permalink)
the best way is to control the pump with a vsd (variable speed drive)
even when it is a pressure pump you still can use a valve to restrict the flow
the solution that jim b sugested can be done but not very elegant (better is to divert the pipe directly to the storage supply if it is a open system (non pressurized loop system))
you will not save any energy on the pump with the last 2 solutions
Robert-Jan
remote control required leaves you only the vsd option
Last edited by rjvh; 6th August 2008 at 08:21 AM. Reason: remote control requirement
rjvh is offline
How much do you pay for gas at the pump ! RODALCO Chit-Chat 109 2nd May 2008 03:39 AM
Dosage pump TCDK Datasheet/Parts Requests 2 22nd April 2008 09:15 PM
Pump stays off if ac power goes off jenny1985 General Electronics Chat 9 1st June 2007 01:55 AM
Help with manual pump! Please Help! turtleg Electronic Projects Design/Ideas/Reviews 6 10th April 2007 02:52 PM
RF Receiver and DC motor running from same power source? adamthole Electronic Projects Design/Ideas/Reviews 15 18th May 2005 09:37 AM
