Old 5th August 2008, 10:20 PM   #1
Default Will this circuit work?
Hello, I am trying to make a circuit for the truth table. I also am not sure if the diode "or" gate will work right. Thanks for the help.
b_reagle is offline
Old 6th August 2008, 12:09 AM   #2
The LS part has a very wimpy high output current IOH. You will never be able to drive that circuit. Why not just use an OR gate? Also keep in mind HC can drive LS parts ok but LS is not always able to drive HC, so you should stick to one logic family. Also why is R6 on your FET? I don't think you want to drive 50 ohms.
Pay it forward.
Mikebits is offline
Old 6th August 2008, 04:29 PM   #3
Thank you Mike,
I am trying to keep parts count to a minimum. I could use an OR gate but that is another chip. I forgot to change the chip families to both HC, as suggested by audioguru, as was R6 also suggested. I want a simple battery operated electric lock to make a motor forward and reverse only stoping when the lock is locked or unlocked. For now, U is a momentary push button. B and C are phototransistors. Maybe I will switch to Light Sensitive Resistors. No, I don't want to drive 50 ohms. I want to use as little as power as possible for the circuitry. All the power should be used only when motor is on, and very little when it is stopped. Thanks for the help.
b_reagle is offline
Old 6th August 2008, 05:22 PM   #4
The 74HC00 will generate only about 2.0V or so across R7 which is only 100 ohms. R7 should probably be several k ohms.
How much voltage does Q3 require to turn on and carry the motor current?
Carl
Curmudgeon Elektroniker
crutschow is offline
Old 7th August 2008, 01:24 AM   #5
I'm having trouble understanding your logic. Does B=1 mean light is present? Same for C=1? Does X=1 mean the motor is on?
Ron
Roff is offline
Old 7th August 2008, 01:31 AM   #6
B= 1 when light is not present. C=1 when light is present. X=1 when motor is on.
b_reagle is offline
Old 7th August 2008, 01:43 AM   #7
Is that part number for your FET correct? I could not find a data sheet for it.
Pay it forward.
Mikebits is offline
Old 7th August 2008, 01:46 AM   #8
Maybe this will help.
b_reagle is offline
Old 7th August 2008, 01:48 AM   #9
http://www.digchips.com/datasheets/p.../IRF3711ZL.php
b_reagle is offline
Old 7th August 2008, 01:50 AM   #10
lol, I thought the Z was a 2. thanks
Pay it forward.
Mikebits is offline
Old 7th August 2008, 01:51 AM   #11
Hi b reagle,
Replace the 74HC00 shit, D1, D3, R5 and R7 with a 74HC51.
I also have a problem with the base currents of the 2N2222's.
on1aag.
on1aag is offline
Old 7th August 2008, 01:57 AM   #12
Why don't you do it like this?
Ron
Roff is offline
Old 7th August 2008, 02:04 AM   #13
Geez, I now have a bright red spot on my forehead from slapping myself. Good one Ron
And a spare gate to boot.
Pay it forward.
Mikebits is offline
Old 7th August 2008, 02:07 AM   #14
I've got an excuse, it's 3 a.m.
on1aag.
on1aag is offline
Old 7th August 2008, 02:10 AM   #15
Yes, I think that is it....The circuit is for an electric dead bolt than runs on batteries. Will all this work at 3 vdc?
b_reagle is offline
circuit, work
CIRCUIT DOESN'T WORK Russlk General Electronics Chat 14 25th November 2008 05:34 PM
How does this circuit work? Andrew Leigh General Electronics Chat 6 2nd September 2008 09:05 AM
Will this circuit work? beluluk Electronic Projects Design/Ideas/Reviews 5 23rd July 2006 05:31 AM
Will this circuit work??? jaxart Electronic Projects Design/Ideas/Reviews 0 30th August 2004 04:33 PM
Would this circuit work? CoTang Electronic Projects Design/Ideas/Reviews 10 8th April 2004 02:04 PM
