| Thank you very much!!! I knew something was just not right. Thanks again.. | |
| Is this right then?? | |
| Isn't the base current 4.9mA in the unnumbered Q's? | |
| I would change R5 to 100 ohms. If you don't need the extra gate, either connect the inputs to GND, or put it in parallel with the "output" gate to speed up MOSFET switching. How much current does your relay require? EDIT: I just saw your last post. R1 and R2 should be around 10k. If you don't get solid "0" levels at B and C, change R3 and R4 to 10k, and R1 and R2 to 100k. Last edited by Roff; 7th August 2008 at 02:34 AM. | |
| I'm not sure. I am not very good at finding such things. mr62-5fsry | |
| I can't find a datasheet. Who made it? | |
| it says: rspo5h2co5s1 mr62-5fsry nec japan .6A 110 vdc 1A 125vac b5321 It is orange I know it it a 5 vdc DPDT relay. No meter this week for me either. $$ I got them in Vocational School 12yrs ago. | |
| Thanks for the help, both of you. Is time (10pm) for bed. The quest will continue tomorrow. Thanks again.. | |
| Hello again, I am having a problem with the circuit you posted Roff. in your circuit X = AB + |AC =1 shouldn't X = A|B = |AC = 1 like this: I am not sure but something is still fishy about the circuit.. Thanks for the help. | |
| Found some stuff on relay. http://www.rjcomponents.com/stock/It...?id=1922001112 This doesn't have to be the relay. I just have a few laying around from school. I just want a low power low voltage(2vdc-6vdc) relay. I am not sure if this is the best way to switch the polarity on the motor. It is the way I came up with for a project. Seems to work fine. I don't see too many people use it though. Mostly h-bridge's. | |
| I don't know. You changed the polarity of the B phototransistor from noninverting to inverting after I posted my schematic. Your new schematic should work, if you want to keep the new orientation of the B phototransistor. | |
| If I switch B then I won't have to invert it right? | |
| Yes. Also, as I said before: Quote:
| So this would be the best way? With 3vdc - 6vdc? And thanks again for your time. | |
| CIRCUIT DOESN'T WORK | Russlk | General Electronics Chat | 14 | 25th November 2008 05:34 PM |
| How does this circuit work? | Andrew Leigh | General Electronics Chat | 6 | 2nd September 2008 09:05 AM |
| Will this circuit work? | beluluk | Electronic Projects Design/Ideas/Reviews | 5 | 23rd July 2006 05:31 AM |
| Will this circuit work??? | jaxart | Electronic Projects Design/Ideas/Reviews | 0 | 30th August 2004 04:33 PM |
| Would this circuit work? | CoTang | Electronic Projects Design/Ideas/Reviews | 10 | 8th April 2004 02:04 PM |
