| Hi Everyone. Looking for help identify an object that is used to open automatic doors. To explain- My Dad lives in a sheltered accommodation complex.Each resident is issued with a key fob that when put in front of a automatic door receiver opens the door. Trouble is these are £20 a throw and we have to purchase a number of these in order to open the door when going to tend to our relatives.Each resident as the same trouble where some families spending £60 or so just so they can get in. I purchased two of these fobs, 1 to get in and 1 to open up to see what worked it. There is not much at all in the fob only what looks like a copper coil and a very tiny metallic object attached to the coil at two points. Many of the residents misplace these fobs and subsequently have to purchase more as only one is issed free I mentioned to some of the residents the fob might work in the form of a wrist watch and they expressed interest in this thought. Can anyone help identify this object and if so what does it do? please see image. Regards Mark Last edited by wombweller; 4th August 2008 at 08:00 PM. | |
| May be hasty but why is my image not showing? Regards Mark | |
| The image is showing now, hopefully someone will recognise it soon, although it doesn't look particularly clear. | |
| The image Mark | |
Unfortunately the object is so Small it's very difficult to photograph so I scanned it instead. The tiny rectangular metallic object in the item in question.It can't be much bigger than 1.5" square. The coil that comes out of it at two points goes around the internal circumference of the case. There are no signs of any power source to this object Mark Last edited by wombweller; 4th August 2008 at 08:30 PM. | ||
| hi mark , i wanna ask u a question, how does that object u sent open the door? do u have to enter it in a speceific hole or is there any button in it?? | |
| It looks like a RFID device. Very specific coding inside, I doubt you can get something off the shelf.
__________________ Pay it forward. | |
| If it is RFID,and it looks like it, and if you bought another, it won't work unless programmed into the system. This is how they keep the unwanted out.
__________________ gerty | |
The fob is palced in front of a sensor on the outside of the door enrty point, you just pass it over the sensor and the electro magnet door lock dis-engages and the door is released. Regards Mark | ||
MMMM!!! i'm thinking you maye right here. I googled for RFID and this is what I found- http://www.technovelgy.com/ct/Techno...e.asp?ArtNum=1 Does this men it is the end of the line for me in finding a cheaper or better solution? or can they be re-produced? it's a very small chip!!! Mark Last edited by wombweller; 4th August 2008 at 10:16 PM. | ||
| In the link you provided, see Zombie tags. You would need a scanner (Not easy to get) and the tech know how to do this. I think your stuck
| the way these tags work is the tag transmits an encrypted number to the reader which then sends it to a central controller which compares the number against authorizations. If OK, it then unlatches the door. You can probably find a reader fairly cheap but the hard part would be constructing a tag that transmits the right code. it's probably doable but you would first have to crack the encryption - I'm guessing it's AES. maybe a better way to do this is find a source for the tags, they are usually a few dollars, er quid, and get the facillity people to use yours. I suspect they put such a high price on them to take into account the need to program the number into the system. | |
__________________ Pay it forward. | ||
| Hi, I guess you are following the wrong trace. A metallic object for access control can't be an RFID chip. It has no conductive areas at all. An I-Button has conductive areas, one for the data and one for ground. If the object you have to hold inside the receptacle isn't much larger than a PC RTC-battery (dimensions F3-type: 3.1mm, dia 17.35mm; F5-type: 5.89mm, dia 17.35mm) and also looks similar it must be an I-Button. To use I-Button access systems without any control is pure waste of money. Each I-Button has a unique number programmed into the chip during manufacturing. For controlled access the ID must be programmed into the control computer to accept a certain I-Button. The type of the button should be engraved in the housing. Normally it is a DS1990A, manufactured by Dallas/Maxim semiconductors. If there is no control at all you might purchase a couple of buttons at Mouser or Digitech for far less than you paid until now. It wouldn't be wrong to post a picture of the "key" here too. Boncuk | |
Yes something I have considered and I would be very careful and keep within the Law. This is the research stage of the project and it might not ever go anywhere.It all depends on where the fobs come from what they are and if there are any council/supplier contracts involved.It might even be that the local Council who own the complex don't have any input to the coding in the device. I can do some research in to who supplies these fobs to the local council. Mark | ||
| opening different file types??? | shaneshane1 | Chit-Chat | 5 | 3rd February 2008 10:49 PM |
| photoelectrically controlled self-opening and speaking trash container | ice-cream-man | Electronic Projects Design/Ideas/Reviews | 2 | 18th January 2008 10:56 PM |
| Mystery Object. | on1aag | Chit-Chat | 8 | 29th December 2007 11:34 PM |
| Microphone without opening mouth | HudzonHawk | General Electronics Chat | 18 | 31st October 2007 10:50 PM |
| Door opening notification | wireguy | General Electronics Chat | 2 | 13th June 2003 11:58 AM |
