| I would like to build an amp for some old stereo speakers I have. I have tried looking up different amp schematics but don't know what kind to use. If I could get some simple direction toward a particular amp type or schematic that would be of great help. I would be using this to amplify a computer or mp3 player source for use with un-amplified speakers. I don't know how many watts those output but a 20 or more watt amp would be good. I have a 24 V .5 A power supply laying around I could use. So if anyone has any good advice that would help. I have experience soldering and working with electronics, just no experience in making circuits and really doing more than assembling them. | |
__________________ Pay it forward. | ||
| That PSU can only output 12W so largest output your amplifier can give is just 8W.
| The little 24VAC transformer will make a rectified and filtered 32VDC. A single power amp with a 32V supply will have a max output of about 28V p-p. 28V p-p is 12.3V RMS which is 18.9W in an 8 ohm speaker. Get a much more powerful transformer.
| 8 till 10 Watt is already a lot of noise i asume that you dont run a disco so for home use it would already be fine Robert-Jan | |
| Use an LM1875. And get a beefier power supply. | |
| Go for a real man supply like this one. http://www.lambda-hp.com/product_html/esspower.htm Intended as humor only
| Just to give you an idea of a part you might use (Available at Digi-key) http://www.st.com/stonline/books/pdf/docs/1478.pdf Guru or someone else can probably suggest a better part. I don't do much audio.
| Ok disregard any thing related to output power I said. I am not familiar with how that is calculated and amplifiers in general. I don't really know what to say, If someone could just refer me to a good schematic of a stereo amplifier that can run off of anything 0-20V or so and has some volume control. I could work with that. I can always get another power supply if needed. I'm just trying to do this as a project and hopefully cheaper than buying something. Thanks for the input so far. | |
All amplifiers have a volume control.
| [quote]I don't really know what to say, If someone could just refer me to a good schematic of a stereo amplifier that can run off of anything 0-20V or so and has some volume control. I could work with that.[quote] Read the LM1875 data sheet. Everything you need to know (schematic, PCB layout, etc) is in there. | |
| The datasheet for the LM1875 shows that its output power is only about 4.5W into 8 ohms when its supply voltage is only 20V. That is flea power for people with rice-paper walls. The LM1875 is designed for a 50V supply. Then its power is 20W for people with cardboard walls.
| ok thanks guys I'll take a look at that then | |
| http://sound.westhost.com/project72.htm Itīs possible to use a lower Voltage supply. The formular for the output power is: P(out) = Vcc^2 / 8*R The output voltage of the amplifier always is at least 3V lower then the input. With the formular you get the peak-power output. The continious output is lower because the supply voltage will sink if the current will get higher. Example: Transformer 24VAC Voltage at condenser = Veff * SQR(2) = 24V * 1.41 = 33.8V Rectifieing needs 1.2V 33.8V - 1.2V = 32.6V Amplifier needs 3V or more 32.6V - 3V = 29.6V 29.6^2 / (8*8 Ohms) = 13, 7 W maximum peak power @ 8 Ohm The minimum supply voltage (for continiuos power) will be at minimum 27V. | |
| That formula gives peak power, doesn't account for the voltage drop across the transistors and I don't know where you got 8*R from.
| I need help with a set of speakers, please! | Mormoran | General Electronics Chat | 24 | 2nd October 2007 12:37 AM |
| LED ans speakers. | pljack | Electronic Projects Design/Ideas/Reviews | 10 | 19th May 2005 11:10 AM |
| Speakers | TekNoir | General Electronics Chat | 4 | 9th May 2005 06:01 PM |
| I Wanna switch 1 amplifier between 3 sets of stereo speakers | lcars | General Electronics Chat | 4 | 19th May 2004 10:19 AM |
| Nokia 9210 Speaker Amplifier And Guitar Amplifier (Plz Read) | PM5K | General Electronics Chat | 2 | 1st January 2004 12:37 AM |
