| Just remember, the gyro alone is not accurate as it drifts allot over time. You need a stable plane or a way to compensate for the gyro drift.
__________________ How To Ask Questions The Smart Way | |
| ok i'll keep that in my mind thanx for every thing , and wigh u the best of luck, c u | |
| hey guys, i wanna ask u somehing that i heared early this evening. it's about using the compass as a yaw rate sensor!!! so is there anyone knows about this thing??? thanx in advance | |
| A compass (magnetometer) will not work while the plane is tilted. You do get tilt compensating units, but even these don't work 100% on the airplanes. btw: The compass will only give heading, you need to take 2 heading readings at a certain interval... do some maths and it will give you yaw rate.
| hello everyone, can u plz look at the pic attatched and tell me if what i stated is right or wrong ?? if it's right: let's suppose that we have a 10 cm fuselage ok, and that the airplane is flying with an attitude of let's say 2m and we send a pitch down command for the airplane, and we want it to produce 30 degree angle of pitch , so depending on the rule whitch says that if we want 30 degree angle of a triangle then the fronting line of the wanted angle must be equal to the half of the rad line so using that would produce the following: as the rad is equal to the half of the fuselage length then rad =5cm, ok! and the half of the rad will be equal to 2.5cm right? so the fronting line must be 2.5cm to get 30 degree pitch angle and as i supposed above that the attitude is 2m=200cm then to provide the wanted angle, that attitue must be decreamented by 2.5cm... so is that right or i'm in the wrong way??? thanx in advance | |
| sensor control comunication | rjvh | Electronic Theory | 15 | 24th June 2008 02:05 AM |
| tracking changes in roll, pitch and yaw? | Chris_P | Electronic Projects Design/Ideas/Reviews | 2 | 8th June 2007 03:15 AM |
| pitch roll measuring | ombrastein | Robotics Chat | 10 | 30th November 2006 03:23 AM |
| voice changer - pitch increase - thanks- still not done tho | solderstuff | Electronic Projects Design/Ideas/Reviews | 8 | 18th October 2004 01:27 AM |
| control play back pitch of a audio | Dmax | Micro Controllers | 4 | 29th February 2004 08:03 AM |
