Old 31st July 2008, 04:37 AM   (permalink)
Red face interlocking switch
Dear all~
I have met a problem and that make me almost crazy.....
My problem is that:
This is a box for hotel rooming use which include 2 toggle switches (ON-NONE-ON) ,
switch 1 : don't disturb;
switch 2 : clean;
Functions:
(1) switch 1,2 are interlocking; both of them will have a LED for indication.
LEDs will on when toggle switches are "ON".
(2) when one of the switches is pushed to either "ON"/"OFF" , it will produced a short voltage pulse to activate a relay for a second. To hold the relay is not necessary.
The main problem is that can those functions be done by relays, toggle switches and capacitors only? Since power consumption is a main problem,
this box can only used battery(with 2200mAh). No transformer can be connected to the box.
Actually, this box is only used to control a remote control.......
THX a lot~
Adrian116 is offline
Old 31st July 2008, 04:51 AM   (permalink)
Originally Posted by Adrian116 View Post
Dear all~
My problem is that:
switch 2 : clean;
Functions:
THX a lot~
Depends on what kind of pulse you need and how long it must be held. And I'm almost positive you'd also need some resistors.
If you want, a nice low-power solution using a CMOS 555 timer chip (common as dirt and just about as cheap) will produce a pulse and you can easily control the length of the pulse.
Can you provide details about the relays or any more details at all about the circuit?
Torben
Curiosity was framed. Ignorance killed the cat.
Torben is online now
Old 31st July 2008, 06:24 AM   (permalink)
Dear all~
My problem is that:
switch 2 : clean;
Functions:
THX a lot~
The one shot 555 circuit is great, but how much rooms do your hotel have? buying (i.e. 25) IC's, plus resistors, transistor and relay, system maninteance, etc. may consume too much space and time.
Why don't you use spring loaded switches?
La Rotta
Menticol is offline
Old 31st July 2008, 07:19 AM   (permalink)
THe pulse is just need to active the relay for a second.
I have tried to use the 555 to hold a long pulse for the led before , but this circuit used up the battery very soon ( approximately a few day).......what i need is one month.....
My circuit is:
http://diagram.51pcb.net/upload/pict...6375164620.gif
Can you show me your circuit?
the relay i used is TAKAMISAWA RY12W-K
Old 31st July 2008, 07:32 AM   (permalink)
555 circuit is great but a low power consumption is much more important...
for my case, i can only provide a battery for my circuit........
It is hard to connect a power supply.
The main problem is the 555 circuit consume too much power and the led
can only light up a few days continuously in my testing...(but i need 1 month)
So, i am thinking how to used switches and relays to make the same functions...
Old 31st July 2008, 07:37 AM   (permalink)
Maybe a global vision of your problem can solve it: What happens when the relay is activated by 1 second? What's the circuit purpose?
La Rotta
Menticol is offline
Torben
The pulse should be enough to activate the relay for a second is ok.
what is your low-power solution? can you should me the circuit?
the one i used before is the attachment
The relay i used is TAKAMISAWA RY12W-K
Old 31st July 2008, 07:45 AM   (permalink)
What kind of batteries are you using, and how many? That relay wants 8.5V on its coil in order to trip.
Also, what (exactly, as in model number) is the 555 chip you are using? There are regular 555s, which consume more power, and CMOS 555s, which do the same thing but the timing can be adjusted further and they use less power.
Also, what kind of LEDs are you using?
How many hours per day must the device have LEDs lit on it, and how many?
Torben
Old 31st July 2008, 07:52 AM   (permalink)
OK, may be my idea is not so good.
Let me told you what i am going to do.
First, i have a remote control with a reciever(just like the car security purpose)
Now, i want to make a box/panel to control the remote control. the panel include 2 toggle switches and leds respect to "don't disturb" and "clean" respectively. Those switches are interlock. for example: when don't disbturb is on, the led for clean will not light even you turn the toggle switch.
Each time you turn the toggle switch will do a action just like you push the button on the remote control once. This is the main purpose. May be it is a little bit stupid....
Actually i can't make this function already with the spring loaded swithes, but the customer want to used toggle switch and the battery can only last for few days......The truth is that they want a month......
Old 31st July 2008, 08:02 AM   (permalink)
Torben
The battery i used is rechargeable 11.1v 1000mAh. The relay should not hold for long time since high power consumption.
the 555 i used is 555D JRC 3092A
the LEDs i used are somehow like the attachment. I think it should consume less than 10mA.
2 LEDs on the panel and lit on about half a day.
Old 31st July 2008, 08:21 AM   (permalink)
Are there other sizes and types available to you? You haven't filled in the location field in your User CP so I don't know how to guess what you might be able to get.
OK, a quick bit of googling didn't turn anything up on those chip markings. Do you know who made it or do you have a datasheet for it?
OK. How are you driving them at the moment?
Torben
Old 31st July 2008, 08:30 AM   (permalink)
You might be able to get away with something like so, Switch goes on, relay momentarily activates until cap charges up and relay goes off. Play with RC values to get right amount of relay closure. Bigger resistor is better as less current draw. That is about as simple as I can think of.
Pay it forward.
Mikebits is online now
Old 31st July 2008, 08:42 AM   (permalink)
Torben
The battery can be changed to 11.1v 2200mAh,
Sorry,what do you mean myCP?
I bought the chips from some store.......sorry , i don't have the datasheet also......
For the LED, i just connect 12v voltage source to the toggle switches with a resistor 680 ohms to it......may be larger resistance is better.
Old 31st July 2008, 08:46 AM   (permalink)
Thank you for your circuit.
Yes, you circuit can solve the relay problem, but the toggle switch will not spring back.......so when you turn on , the relay will hold until you turn the toggle switch to off....but i need to activate the relay when it turn to off and on, do you get what i mean? Each time you turn the toggle switch, the relay will hold a second and return to the normal state.
Old 31st July 2008, 08:50 AM   (permalink)
As soon as you toggle your switch, the relay will activate until cap is charged and then decactivate. Circuit will not toggle again until switch is turned off and then back on.
Pay it forward.
Junebug Tip & Trick #1, Using the DIP switch as a 4 bit mode switch blueroomelectronics Micro Controllers 2 15th May 2008 11:43 PM
switch on a led depending on the switch state (using picbasic and pic16f877) pouchito Micro Controllers 8 8th June 2007 09:09 AM
Need to detect momentary switch and switch 12V, simply iso9001 General Electronics Chat 9 17th April 2005 09:31 AM
convert a manual switch to an electronic switch dolphin Electronic Projects Design/Ideas/Reviews 1 1st September 2003 06:04 AM
Noise Activated switch w/ 2 second delay for switch off tbank Electronic Projects Design/Ideas/Reviews 0 13th June 2003 12:04 AM
