| You could alter the DPI setting to make system fonts larger, rather than using a lower resolution.
Torben
__________________ Curiosity was framed. Ignorance killed the cat. | ||
| Thanks, I will try that.
__________________ Pay it forward. | |
| I think the range of the remote control should be selected not to be so large, so that we can arrange the remote control sets as the picture shown. I think the signal will not overlape. How about your suggestion? | |
| Hi, Bit tired .... and pondered this so long that i'm not sure ive got it right .... Also havent included the LED indication, another set of three probably. As shown, should be minimum battery draw, and quenching of the cap thats not in use, so that even mistaken switching between positions should not be a problem. John ****************** ![]()
__________________ ************************************************** *************** Last edited by john1; 6th August 2008 at 04:15 AM. | |
I took your image and modified it. I see what your thinking here but here is the thing. With limited range Transmit, the receiver would have to be close enough for coverage. Look at my image, with coverage for Area 1, then Area 2 would not be able to transmit to RX1. Only way I see around this is multiple receive units, is that your plan? Also is the reciever able to receive multiple frequencies? Say room 1-3 frequency?
__________________ Pay it forward. | ||
| Adrian, I don't think you ever answered my question about how far the devices must be able to send. Will there be a portable unit in each room which must reach only to a display unit on the door, or must all rooms be able to send individual signals to a central location somewhere in the hotel? Torben
| Going by Adrians previous image. It would appear that there is a seperate remote for each room, ie. room 1 has freq 1, room 2 uses freq 2 etc. The drawing provided by Adrian would also imply a multi channel RX which I questioned. Adrian also assumed he could use redundant remote frequencies which would not interfere based on distance from TX room 1 with TX room 4, which would force multi RX units to maintain full floor coverage. IMHO this plan is not to workable as is. Perhaps the wireless idea be thrown out in lieu of a wired approach like a multi addressable 2 wire bus where the wires are ran under carpet or something. I dunno...
Not all rooms should sent the signal to central. The cleaner will check the outdoor LED indication. Just show the alarm outside the door is good enough. The range of the signal to be send , i think 400 feet square is good enough. | ||
| | (permalink) | ||
| Hi Mike! Quote:
If it's the first option, then Adrian's diagram might work, since no remote needs to be able to send a signal further than that room's door. If it's the second option, then I agree with you, and some other communication method should be looked at. I was thinking about Wifi or Zigbee modules, perhaps. Quote:
Torben
__________________ Curiosity was framed. Ignorance killed the cat. | |||
Just a thought
Actually this kind of service should be done with wire and is more reliable. I think the haven't consider about that when they construct the building. Also each time the battery is used up , they need to recharge them. But there are may be some hundred rooms. Also , i don't think this idea work properly. I also asked my boss why don't they used wire. He told me that it is hard to provide voltage source for that device...... | ||
| | (permalink) | |||
Torben
__________________ Curiosity was framed. Ignorance killed the cat. | ||||
If each control unit only ever needs to communicate with its own display unit at the door, then wouldn't just two wires for the commands be enough, and not even need to be addressable? Two bits is enough to represent four states, and we only need to represent three states. Torben
| Junebug Tip & Trick #1, Using the DIP switch as a 4 bit mode switch | blueroomelectronics | Micro Controllers | 2 | 15th May 2008 11:43 PM |
| switch on a led depending on the switch state (using picbasic and pic16f877) | pouchito | Micro Controllers | 8 | 8th June 2007 09:09 AM |
| Need to detect momentary switch and switch 12V, simply | iso9001 | General Electronics Chat | 9 | 17th April 2005 09:31 AM |
| convert a manual switch to an electronic switch | dolphin | Electronic Projects Design/Ideas/Reviews | 1 | 1st September 2003 06:04 AM |
| Noise Activated switch w/ 2 second delay for switch off | tbank | Electronic Projects Design/Ideas/Reviews | 0 | 13th June 2003 12:04 AM |
