| Quote: I have some more questions. Some of these questions aren't about the actual circuit, but they may help us help you better if the answers mean that we can look at other possible solutions. Is this actually for a large-scale installation in a real hotel? If so, how many rooms must be serviced, and what is the expected range? Is using the remote controls your idea, or the hotel manager/owner's? I ask only because it sounds like they already have something central installed. Do you know for sure that you can get enough remote controls with unique codes/addresses/frequencies/whatever to handle all the rooms? Why do you want to do this with relays and capacitors only? If semiconductors and ICs were allowed it could possibly be made smaller and cheaper. What is your expected budget for each unit? What about the budget for the whole system? What is your deadline? What electronics experience do you have? Do you have the ability to load HEX code onto a microcontroller such as an 8051 or a PIC or something? Would it be possible to use a rotary switch instead of a toggle? I am sure I've forgotten some questions but if you can answer the above it might help us to help you. Torben
__________________ Curiosity was framed. Ignorance killed the cat. Last edited by Torben; 5th August 2008 at 07:24 AM. Reason: Pluralization fix. | ||
| Ya know, when I was in the Navy we had this piece of gear for sat-comm stuff. Anyways I remember it had this really cool switch on it. It was 3 way, but middle position was push button. Now that would be cool, just can't figure out what you would call it. So it was like ON- PB -ON. I ordered a few switch catalogs to see if anything resembles what I remember. _______________Edit__________________ Brain fog is clearing. It was a rotary knob switch, with a center PB...
__________________ Pay it forward. Last edited by Mikebits; 5th August 2008 at 07:33 AM. | |
| | (permalink) | ||||||||||||||
| Hello again Adrian, Quote:
Thanks for the answers, and if you can answer the above questions (and any others you think we might ask) things can move forward. Torben
__________________ Curiosity was framed. Ignorance killed the cat. | |||||||||||||||
| Is this switch like the one shown in the attachement? | |
| Yo Adrian... If I may make a few suggestions as well. You need to lock down what you really need and why? You as the one being tasked to perform the design must know all the details of what is needed, such as number of rooms, remote interfaces, how is communication performed. Interfaces to the remote reciever. Before you can really pursue this to an end, a set of requirements must be determined. At this point, it seems as those we are spinning our wheels. Do not think I am getting annoyed or anything, as I and most others here like to help. It's what we do, but my request to you is this. Nail down what you actually need, perhaps start with a system level diagram. Make sure you have the overall picture in your mind and on paper. When you say to me that you are not sure how the remotes communicate I worry as it shows you do not yet have a good understanding of your own design. If you do not know, it is difficult to offer help. Perhaps you should consider alternatives to your remote and look into wireless links designed for multi users. Or maybe even running wired multidrop serial comms. What I am saying is that before we can help, you need a better idea of all the task and functions of your system. Take charge as Project Eng, set requirements, such as one switch for this, no that, etc. Get what I am saying?
__________________ Pay it forward. | |
| Got link? I like to look at the data sheet. Cool
| OK, I've solved the problem as originally posted, but I do NOT suggest this as a final solution. I'm too tired to draw the whole thing out including the DPDT toggle switch wiring but the following should illustrate the idea. I'll try to get the DPDT wiring drawn out tomorrow if anyone is interested. This solution requires three relays (SPST, although I have used DPDTs in testing and the schematic shows SPDTs), one DPDT toggle switch (centre-off), one 2N2222, a couple of signal diodes, two 100uF caps, and a handful of resistors and LEDs. It's pretty bulky and a little power-hungry for my taste but I've just carried the idea this far to see if I could come up with something which could do the job using the original relays-only requirement. Also, this is running on 12V, because that's what my relays need. In the schematic shown the LED resistors are chosen for low-power 2mA LEDs with no thought yet given to differing red/green LED current requirements. ![]() Torben
__________________ Curiosity was framed. Ignorance killed the cat. Last edited by Torben; 5th August 2008 at 09:56 AM. Reason: Fixed the screwed-up diode connections in the schematic. | |
| Actually, my boss just want to know if such functions i asked before can be done. the remote control set i used to test is somehow like these: | |
| Ugh Torben, you must be using real high res settings. Your image sends all your text way off my screen. My eyesight is not so good so I stick to 1152x864. Why two leds per trig branch? Does that setup up currents or something for the cap? I still like my circuit as it only needs 10 parts, no relays. Not as bullet proof as yours though
| | (permalink) | |||
Torben
| From the pics, I do not see how you could ID one remote from another. Do you have link for remote?
Torben
| I mean identification. How will you know one remote from another? If they all put out same frequency and codes, it will be hard to know which room is requesting service. See what I mean?
__________________ Pay it forward. Last edited by Mikebits; 5th August 2008 at 11:19 AM. | |
| Junebug Tip & Trick #1, Using the DIP switch as a 4 bit mode switch | blueroomelectronics | Micro Controllers | 2 | 15th May 2008 11:43 PM |
| switch on a led depending on the switch state (using picbasic and pic16f877) | pouchito | Micro Controllers | 8 | 8th June 2007 09:09 AM |
| Need to detect momentary switch and switch 12V, simply | iso9001 | General Electronics Chat | 9 | 17th April 2005 09:31 AM |
| convert a manual switch to an electronic switch | dolphin | Electronic Projects Design/Ideas/Reviews | 1 | 1st September 2003 06:04 AM |
| Noise Activated switch w/ 2 second delay for switch off | tbank | Electronic Projects Design/Ideas/Reviews | 0 | 13th June 2003 12:04 AM |
