Old 3rd August 2008, 01:28 PM   (permalink)
One point. How about the middle switch position detection that the OP wanted? Another switch pole maybe?
Pay it forward.
Mikebits is offline
Old 3rd August 2008, 02:19 PM   (permalink)
Hi Ken,
You have improved on that circuit.
As to the red and green, Adrian doesnt mention anywhere that he will use two different colours, but yes it is quite reasonable to think so.
And yes, to appear similar brightness they would need slightly different resistors.
Curiously, i was also thinking that the switch might be able to discharge the opposite capacitor but i didn't set anything down, nor did i think how it might do that.
I was thinking along those lines, simply to enable the use of reed-switches, but i did not actually come up with anything.
I am most taken with the simplicity and small number of components in this circuit.
I have taken the liberty of re-drawing the same circuit, using reed switches, and adding a picture of the type of switch.
The OP (original poster) has a choice of ordinary relays or reed switches.
As to the contacts getting damaged, ive abused relays for years and i think that any normal relay could discharge a few microfahrads without a problem, but using the switch is of course much better.
We have not heard from Adrian in a while.
Regards, John
john1 is offline
Old 3rd August 2008, 02:26 PM   (permalink)
That is pretty clever
Pay it forward.
Mikebits is offline
Old 3rd August 2008, 02:27 PM   (permalink)
Mikebits,
Just seen your last post,
Did Adrian want indication for the "OFF" ... ?
I dont recall that, he may have mentioned it as a possibility, i could look back i suppose.
Cheers, John
last but one now
john1 is offline
Old 3rd August 2008, 02:31 PM   (permalink)
an indication for the OFF might be difficult,
as those type of switches have no contact in the middle position.
john1 is offline
Old 3rd August 2008, 02:35 PM   (permalink)
Here is the requirements as I understand them.
There is a switch in the room which the customer can set to "Please clean", "Clear", or "Do not disturb".
Any time the switch is moved to "Please clean" or "Do not disturb", the corresponding LED is lit and the corresponding button on the remote control should be activated. There will be duplicate LEDs on both sides of the door, so that both the customer and the cleaners can see them.
Any time the switch is moved to "Clear", any lit LEDs must be turned off and another button on the remote control will be activated.
With that said, I would recommend holding off anymore effort until we hear something from OP. This could turn into a talking to ourselves sorta thing
Pay it forward.
Mikebits is offline
Old 3rd August 2008, 04:18 PM   (permalink)
Mikebits,
I agree!...I'm putting my brain on hold. Oops...there I started thinking again.
Reading back over the thread, it looks as if Adrian has changed perameters as different questions came up...like adding "Clear" and 4 LEDs as opposed to two, from Torbin's attempt to flesh out the design requirements.
Ken
KMoffett is offline
Old 3rd August 2008, 04:53 PM   (permalink)
Originally Posted by john1 View Post
Mikebits,
Cheers, John
last but one now
Hi John, I'm sorry to reply so late because my LCD have some problem that nothing was shown.......
Actually, indication for the "OFF" is necessary for a single 3 ways switch since the customers may choose neither "clean" nor "don't disturb",
But the difficulty should be focused to if there have such a switch which appeared in your designed circuit.
"OFF" function can be eliminated if two 2 ways switch are used. But remember that they should be interlocked.
Thank you John for helping~
Adrian116 is offline
Old 3rd August 2008, 11:02 PM   (permalink)
Hi Adrian,
Hope your LCD is alright now.
Could you accept the off as being neither "clean" nor "don't disturb" ... ?
Unless you want it as some sort of 'double-check' ?
I'm afraid i am having trouble following the rest of your post.
Using a single switch,
is effectively "interlocked",
because it can only be in one position at a time.
Cheers, John
john1 is offline
Old 4th August 2008, 02:33 AM   (permalink)
Hi Adrian,
Cheers, John
The off being neither "clean" nor "don't disturb", then what the "OFF" function be? Actually the "OFF" is used turn off either "clean" or "don't disturb" alarm.
I am also think that a single switch is better. You may forget about 2 toggle switches
Old 4th August 2008, 09:39 AM   (permalink)
I started thinking about this a little more, and I came up with something I thought might work for ya, and it is very simple to construct. To boot, you do not even need to reverse engineer your remotes as this will just wire in place of a remote switch.
Now I do violate your single switch rule but before you dismiss this idea read on. This configuration would have two switches, one would be dual DPDT with OFF and two momentary contacts. Like
Momentary - OFF - Momentary
Second switch would be a pushbutton used to clear alarm. Also this circuit uses no expensive relays and consist of 10 parts.
So 1 switch set alarm and notifies remote and lites LED, other switch clears LED and notifies remote.
Parts List
  • SW1 - Pushbutton switch
  • SW2 - Dual DPDT
  • Q1-Q2 SCR Value TBD
  • D1-D2 LED value TBD
  • R1-R4 Resistor
I did not select any parts as I did not want to do the research and find this idea is not going to be to your liking. So will help select values if you wish to continue.
One question, what will the remote be doing? will it notify a computer or something?
Circuit attached
Pay it forward.
Mikebits is offline
Old 4th August 2008, 10:55 AM   (permalink)
Circuit attached
Is the switch 1 used to reset all the alarm status to "OFF"?
Is your idea like the following?
Toggle the "momentary-off-momentary" button to set either "clean" or "do not disturb " to alarm status. If I want to reset the alarm status to "OFF", press the reset button, isn't it?
the remote is used to notify a receiver, the remote and the receiver is a set of security device.
Thank You.
Old 4th August 2008, 11:12 AM   (permalink)
Yes
Yes that is my thinking.
How will the receiver know which remote is activated? Is there some sort of ID sent with each remote?
Thank You.
Well, I think you get the idea.
Pay it forward.
Mikebits is offline
Old 4th August 2008, 12:38 PM   (permalink)
[quote=Mikebits;333500]How will the receiver know which remote is activated? Is there some sort of ID sent with each remote?
QUOTE]
er............i don't know actually.......
i think the signal frequency to be sent is different for differnet button.
Old 5th August 2008, 12:02 AM   (permalink)
Hi Mike (and Adrian and John and Ken),
I was up late last night putzing around with this idea and came to a few conclusions, which it looks like Mike has also reached.
The whole thing would be fairly easy if we assumed the use of a 3PDT switch instead of a DPDT switch--otherwise Mike's idea of the separate "Clear" button is necessary. Using a DPDT centre-off toggle switch and a pair of relays I built a simple circuit which pulses the relay and lights the appropriate LEDs. I wired the DPDT switch so that when going to "Please clean" it would discharge the capacitor on the "Do not disturb" side and vice versa as Ken suggested, but I haven't yet figured out how to wire it to do that when returning to the centre-off position. I'm not sure it can be done without the 3PDT switch. Anyway, this means that the thing can still be confused by switching rapidly back and forth between centre and one side. Rapid switching all the way from one side to the other works fine, though.
Getting the centre-off position to trigger a pulse on a third relay is also slowing me up. I am currently thinking about diode-transistor logic to try to get that effect.
However, it seems to me that the unit will wind up being fairly bulky in the end if it contains three relays. If the remote control contacts need only that one side be brought high or low then using transistors instead of relays may be able to save quite a bit of space (and some current too).
Anyway, I'm kinda rambling here. I have to go do some housework but I'll take another look at this later on.
Mike's question about whether the remotes have unique codes or frequencies or such is a really, really good question too. The whole system would kind of break down if one unit triggered the central receiver for several rooms.
Torben
Oh yeah. I've attached the basic schematic I've been using so far. It's drawn just for one side and only addresses the pulse generation. If I get a bit more time later on I'll draw out what I actually have wired up. This is just the RC differentiator/relay portion of the circuit.
Curiosity was framed. Ignorance killed the cat.
Torben is offline
Junebug Tip & Trick #1, Using the DIP switch as a 4 bit mode switch blueroomelectronics Micro Controllers 2 15th May 2008 11:43 PM
switch on a led depending on the switch state (using picbasic and pic16f877) pouchito Micro Controllers 8 8th June 2007 09:09 AM
Need to detect momentary switch and switch 12V, simply iso9001 General Electronics Chat 9 17th April 2005 09:31 AM
convert a manual switch to an electronic switch dolphin Electronic Projects Design/Ideas/Reviews 1 1st September 2003 06:04 AM
Noise Activated switch w/ 2 second delay for switch off tbank Electronic Projects Design/Ideas/Reviews 0 13th June 2003 12:04 AM
