Geology is my passion of late, more so than electronics.
__________________ Pay it forward. | ||
The remote control is not in my hand now....... | ||
Put black lead of meter to - terminal of remote battery. Now put red lead to one side of switch on remote. This may be hard as many remotes just fall to peices when you take them apart. Anyways If you manage to get your lead on the switch look for one side that reads something like battery voltage. 3V maybe. Then press the switch and observe the meter, the volts should go to zero. What you are looking for is one side of the switch that changes condition from +volt to 0 volt or vice versa. May take some time to get all your hands in the right place, a helper would make it easier. Did that make sense?
__________________ Pay it forward. Last edited by Mikebits; 1st August 2008 at 09:05 AM. | ||
| Thanks for clarifying that Mike! I had to head to bed. . . Torben
__________________ Curiosity was framed. Ignorance killed the cat. | |
| Hi, I am putting forward this skeleton diagram, not as an answer but as a possibility. As can be seen, there is no resistor in series with the cap, thats ok on a small dry cell battery run unit, the cap wouldn't be large anyway. It wouldn't be ok on a larger re-chargeable battery unit, which is why i asked if the intended relay and switch box was meant to use the same battery or one of its own. Mikebits, previously i mentioned using an arrangement where a cap or caps would charge, then would only use leakage current. Rather than using a cap to close a relay using its charging current. Although the difference to the relay may be insignificant, it requires an extra resistor, which unfortunately has to remain in circuit. Using a cap or caps from a charged condition means that (for this) the discharge into the relay coil determines how long the relay operates. The cap would be chosen to give the period required. Just as you have already shown in your diagram, but round the other way. You have put 1 Mfd caps, i would have guessed at around five or six. The advantage to doing it like this would be to minimise battery current. (also i am fiddling about, trying to see if the posts will support an image, i dont think they will, but i'll have a go) Regards, John ![]()
__________________ ************************************************** *************** Last edited by john1; 2nd August 2008 at 01:16 AM. | |
| well maybe they will.
__________________ ************************************************** *************** | |
| Hey guys, i am so sorry that to leave msg so late....... I can't get the remote now since the customer is testing it. May be you guys enjoys your weekend first~ Thank all of you so much~ | |
| Hi Adrian, I've posted another picture. Same arrangement, just filled in a few bits. This should use no battery current, except capacitor leakage, which is almost shelf-life for most batteries. Until its used, then its just LED current until its switched off again, then a little to recharge. I think its battery should cover a month, or more. **************** I shall try to have a nice weekend, i am attemping to put together a solar collector, just to warm water a bit to reduce my bills. The gas company which is selling gas to British consumers, (not petrol, but gas which is the consistency of air) has just put their prices up by "35 per cent" which is actually more than forty per cent to most of us. They call themselves 'British Gas' but they are owned and run from abroad by unknown groups, for profit. And a jolly good profit they make too. Last year, Two thousand million pounds sterling. Very nice. Not so nice here, in the cold. **************** Apart from that, i am really quite happy. John ************* ![]()
__________________ ************************************************** *************** Last edited by john1; 2nd August 2008 at 08:05 PM. | |
| Just noticed a problem with my submission. I dont think the toggle type switches have a connection in the middle position. So, unless anyone knows of a type that do have a connection in the middle, then that arrangement i posted wont work. Or the OP could consider a rotary type. Meanwhile i will have a little think, in case theres a way to do it without a connection on the middle position. ( yes i know i can remove the posts, but i just dont care. ) And i did get a little heat from my solar collector, made out of an old radiator painted black. Haven't piped it in, still experimenting. Cheers, John
| I still think a µcontroller, with Mosfet's switching his "remote control " is the best "low power" solution. But since I was playing with relay switching in another thread I came up with this "all in my head" circuit...no bench testing...therefore no component values. Ken Thought I should add my first concept too....the second image.
__________________ "To invent, you need a good imagination and a pile of junk." Thomas A. Edison (1847 - 1931) Last edited by KMoffett; 3rd August 2008 at 10:35 AM. | |
| Hi Ken, Thanks for adding your relay based idea possibilities. If the OP has only limited electronic experience, very often relays are a practical solution. working with integrated circuits is all very well, but relays can often be much simpler. Ken, i have looked at your circuits closely, and they are (of course) correct in their operation. They use standard type relays with c/o type contacts. I was thinking of reed-relays because of their low power requirements, however, the relays would only be operated a brief period, so maybe standard types are Ok. Plus with standard types, one can see the operation of the unit, which can be important to the person making the unit. I rather like the added contacts on each opposite capacitor, because: Without them, if the user goes from one position to the other, a couple of times before leaving it in the position he intends to leave it, then the cap could retain enough charge during switching to malfuntion. However the inclusion of these extra contacts ensures that the cap is discharged each time the switch goes to a choice. This was something which had me going, namely repeated or accidental switching by the user, which with one of my earlier circuits would be a problem, so i did not include it. I dont see from your post which of the circuits is the one you recommend, i assume its the one with the extra contacts. I can see no improvement to this circuit, other that simply using a single resistor for the LEDs, which is hardly worth mentioning. In fact, i think you have nailed it with that circuit. Regards, John
| John1, Another iteration. In order to use the smallest capacitors possible for the delay, you need relays with the hightest coil resistance for the given battery voltage. This implies miniture relays. This also means relays with low contact current ratings. Using small relay contacts to short out the capacitors would probably shorten their life. So, I just replaced the second set of relay contacts with a second set of contacts on the toggle switch. Might be even cheaper. Ken Because red and green LEDs have different light outputs and voltage drops for a given current, I chose two resistors to allow for optimization for lowest current on each.
__________________ "To invent, you need a good imagination and a pile of junk." Thomas A. Edison (1847 - 1931) Last edited by KMoffett; 3rd August 2008 at 12:29 PM. Reason: Added comment | |
| Junebug Tip & Trick #1, Using the DIP switch as a 4 bit mode switch | blueroomelectronics | Micro Controllers | 2 | 15th May 2008 11:43 PM |
| switch on a led depending on the switch state (using picbasic and pic16f877) | pouchito | Micro Controllers | 8 | 8th June 2007 09:09 AM |
| Need to detect momentary switch and switch 12V, simply | iso9001 | General Electronics Chat | 9 | 17th April 2005 09:31 AM |
| convert a manual switch to an electronic switch | dolphin | Electronic Projects Design/Ideas/Reviews | 1 | 1st September 2003 06:04 AM |
| Noise Activated switch w/ 2 second delay for switch off | tbank | Electronic Projects Design/Ideas/Reviews | 0 | 13th June 2003 12:04 AM |
