| If i had to write this for a chinese forum, i would get the assistance of someone who could write Chinese. I would be unlikely to be able to read it myself. I wouldnt know if it made sense or not. One of the things that are curious, is the interlocking arrangements of the switches. As Mikebits has said, couldn't the customer have a "do not disturb" sign, and flip it over for "clean" ? Well, the customer could, if the card were regularly checked by the cleaners. But this arrangement (i guess) is supposed to operate a radio sender, to inform the staff. But Mikebits raises a good point, namely that a card has only two sides, so why have two switches with interlocks ...? Maybe the original poster doesnt want two switches, he wants to use switches with two positions, " ON - OFF - ON " and maybe this got lost in the translation. Why have two switches with interlocks ? I think he only needs one switch per box. If i am wrong, i assume he will soon say so. ***************************** So, one switch ... yes ? maybe. ***************************** Quote:
I am going to assume that this means an LED on each side, one for "Please Clean" and the other for "Please do not disturb" ............................. What else could it mean ? Well it could mean that the status should be shown at the customers box, and also at the cleaners room. Yes, i think thats it. Again, not obvious, but better than i could put it using Mandarin. **************************** Initially i was thinking of one relay, but now i think two might be needed. Also, the battery conservation ... Mikebits, that arrangement uses current all the time. An arrangement where a cap charges, then stops taking current would only use leakage. Such an arrangement could switch the already charged cap, to one of two relays. The relay would only close for a short interval, but enough to send the info to the staff. As to the LED current, i think that could be minimised. A small LED might light adequately on maybe 2000 ohms. Maybe even a higher resistance. If the staff return the box to "OFF" then the battery might last a month or more. I dunno that the box needs to send any signal for "OFF" **************************** One more question, will the remote sender be using the same battery as the LEDs and relay(s) ? Of course it will. And will the remote sender have to send different signals for "CLEAN" or "OFF" or "DONT DISTURB" No, only for "CLEAN" or "DONT DISTURB" This has been re-written a few times. I know it is untidy. Cheers, John
__________________ ************************************************** *************** Last edited by john1; 1st August 2008 at 05:20 AM. | ||
| Hi John! I have these same questions. Why two switches and not one switch with three positions? Another question I have: why relays? Could not transistors be used and thereby save a lot of current? If I understand the requirements correctly, they are:
Adrian, is this correct? Torben
__________________ Curiosity was framed. Ignorance killed the cat. | |
| [quote=john1;332534]If i had to write this for a chinese forum, i would get the assistance of someone who could write Chinese. I would be unlikely to be able to read it myself. I wouldnt know if it made sense or not. One of the things that are curious, is the interlocking arrangements of the switches. As Mikebits has said, couldn't the customer have a "do not disturb" sign, and flip it over for "clean" ? Well, the customer could, if the card were regularly checked by the cleaners. But this arrangement (i guess) is supposed to operate a radio sender, to inform the staff. But Mikebits raises a good point, namely that a card has only two sides, so why have two switches with interlocks ...? ..........QUOTE] Actually, it is ok to use a three ways toggle switch ("ON"-"OFF"-"ON")~ If such kind of switch is used, there is no need to make a interlocking switch. but the difficulty is that there are only 6 pins on the switch (may be there is such switch with more pins). I don't know if each status have a pair of pins. How to make a short pulse to activate the relay each time you turn the switch. May be it's better to tell the actual condition. PS: the original remote control set is control like that: Each time you press the button. The status of the reciever will hold and return to original status when you press the button on the remote control again. Assume there is only one 3 ways toggle switch. 1. I am the customer now. I am having the bath and do not want any disturb. So i turn to do not disturb. then the LED on the control box and reciever lit up. 2. After i finished the bath. I turn the switch to middle, then the LED on both side will off. In this procedure. How do you activate the relay for both actions? This is the difficulty. The original remote control will use it's own battery which can last for over one month. The box will use another battery. Of course both of them can use the same battery. Thank you for your suggestion | |
Yes , you are right. But one thing should be reminded that the relay to activate the remote control must be a pulse for a second. Can't hold the activate status. | ||
Torben
__________________ Curiosity was framed. Ignorance killed the cat. | ||
But i think the button on it is used to give a pulse to make it "on" and make it "off" by pressing the button again. The button should not be hold. What info. about the remote control you want? I will try my best to tell you | ||
I will think about this some more over the next couple of hours and see what I can come up with. Torben
| I admit, my circuit was somewhat crude as I stated earlier, but without knowing Adrian's background in circuits I attempted to keep it real simple, but I was not happy with it. But Adrian rest assured, now that Torben is on the case you will have a solution. This guy sometimes goes as far as to build a prototype to make sure something works before he gives the circuit to ya. Your in good hands. Oh Adrian, dont forget to watch the eclipse over there in China on Friday
__________________ Pay it forward. Last edited by Mikebits; 1st August 2008 at 07:01 AM. | |
| | (permalink) | |||
I'm taking a swing at the problem but that's no guarantee of anything. Any help you can give me will be much appreciated! Your circuit is giving me ideas too. Quote:
Torben
__________________ Curiosity was framed. Ignorance killed the cat. Last edited by Torben; 1st August 2008 at 07:21 AM. | ||||
Anyways the Eclipse is solar, suppose to occur at 7:08 a.m. to 7:10 a.m. ET.
__________________ Pay it forward. | ||
This is a Solar eclipse~ I will watch it surely~^^ I have never seen this before~ | ||
| Wow, it is even on Wiki. http://en.wikipedia.org/wiki/Solar_e...August_1,_2008
| | (permalink) | ||
Do you know what voltages those lines have on them? For example, when you press the button, does a +V line connect to ground? Do you have any photos of the opened remote control, showing the circuit clearly? Quote:
Torben
__________________ Curiosity was framed. Ignorance killed the cat. | |||
| I would assume active low, but then again I wonder if some use that row column scan method. Been awhile since I have looked at a remote.
Now that I come to think of it, San Diego is also a beautiful place to visit. Jade plants as big as trees, great weather, etc. Torben
| Junebug Tip & Trick #1, Using the DIP switch as a 4 bit mode switch | blueroomelectronics | Micro Controllers | 2 | 15th May 2008 11:43 PM |
| switch on a led depending on the switch state (using picbasic and pic16f877) | pouchito | Micro Controllers | 8 | 8th June 2007 09:09 AM |
| Need to detect momentary switch and switch 12V, simply | iso9001 | General Electronics Chat | 9 | 17th April 2005 09:31 AM |
| convert a manual switch to an electronic switch | dolphin | Electronic Projects Design/Ideas/Reviews | 1 | 1st September 2003 06:04 AM |
| Noise Activated switch w/ 2 second delay for switch off | tbank | Electronic Projects Design/Ideas/Reviews | 0 | 13th June 2003 12:04 AM |
