| sir, how can i built one circuit to convert 5v to 15v dc-dc using IR2110 drive? The nominal output current shall be 5 A Last edited by syedhafizi; 30th July 2008 at 03:58 AM. | |
| خوش آمد The IR2110 is a MOSFET driver. It therefore requires the use of MOSFETs to do what you want. My advice would be to pick suitable MOSFETs for your current drive, (at 5A, that'll be easy). As for the DC/DC converter, I would use a basic toroid with freewheeling diode on the output side of the MOSFETs, and use a simple oscillator to drive the 2110. There are many examples of this type of circuit out there. IR has some app notes that should also help, as does Linear Tech. HTH.
__________________ "Everything that is done in the world is done by hope." -Martin Luther "There are two ways to live your life. One is as though nothing is a miracle. The other is as though everything is a miracle."-Albert Einstein | |
| thanks analog for your reply. but can u give me an example website with that circuit u said. what do you mean by "u will using basic toroid with freewheeling diode on the output side of the MOSFETs, and use a simple oscillator to drive the 2110" | |
| Some one...help me.... | |
| No IR2110 is needed, nor any gate driver. Use a PWM control IC with an output that drives low side n-channel FETs. A complimentary emitter follower can buffer the gate drive and provide the peak amperes to drive the FET gate. Otherwise a complimentary FET driver can provide the drive. The topology for this application would be a boost converter as long as isolation is not needed. If galvanic isolation is needed, then a flyback or forward converter is recommended.
__________________ Claude Last edited by Claude Abraham; 4th August 2008 at 02:43 PM. | |
| this is my project n I MUST use IR2110 for this 5v to 15v converter as condition Last edited by syedhafizi; 4th August 2008 at 07:23 PM. | |
| 3.5” Hard Drive Physical Size, True 3.5” drive? | stevef22 | Datasheet/Parts Requests | 4 | 14th September 2007 03:49 AM |
| DC v/s AC drive | aleen | Electronic Projects Design/Ideas/Reviews | 6 | 10th June 2007 04:22 PM |
| IRF 740 Drive circuit for Boost Converter | bdvs | Electronic Projects Design/Ideas/Reviews | 3 | 11th April 2007 10:52 PM |
| Converting Normal pc cd rom drive to dvd drive | litto43ph | Electronic Projects Design/Ideas/Reviews | 8 | 29th January 2006 08:09 PM |
| Monitor Converter: NTSC/PAL to VGA/SVGA scan converter | NOSREME | Electronic Projects Design/Ideas/Reviews | 0 | 21st June 2005 03:46 AM |
