Old 28th July 2008, 11:10 PM   (permalink)
Smile incubator circuit help*
can u help me for a incubator circuit?it should be maintained at 37 degrees celcius to 38, with a 25-w heating element and 10-w exhaust fan. tnx muah
kyrie2 is offline
Old 28th July 2008, 11:15 PM   (permalink)
pls help me with this
kyrie2 is offline
Old 28th July 2008, 11:40 PM   (permalink)
Default Incubator
Hi cyrie,
here are complete schematic diagram and a single layer PCB layout for the incubator. The zipped file also contains a suggestion for an incubator box.
Adapt the number of heating resistors to the size and ambient air temperature of the incubator box.
Schematic and PCB layout made with Eagle version 3.55. Can be used with version 4.16; for version 5.0 it must pass through 4.16 first. (and be saved using that version)
Having problems PM me.
Note: The circuit does not contain a humidifier.
Boncuk
Boncuk is offline
Old 28th July 2008, 11:58 PM   (permalink)
Originally Posted by kyrie2 View Post
can u help with the incubator circuit? we have projects incubator circuit design, it should be maintained at 37 degrees celcius to 38, with a 25-w heating element and 10-w fan. tnx muah
1) As Boncuk alludes to, you need a humidifier, unless your cultures are completely sealed, as in screw-capped tubes. Petri dishes need the humidifier. A pan of water in the bottom works fine.
2) Are you sure you need 37° and not 35°C? What are you growing?
John
jpanhalt is offline
Old 29th July 2008, 12:30 AM   (permalink)
Aligator eggs.
Over 37 deg they come out male.
Below 35 deg they come out female.
Thirty six can be either way.
Or something along those lines, its been a long time.
John
john1 is offline
Old 29th July 2008, 12:52 AM   (permalink)
37 deg incubators are common in a BIO lab. From stressing plasmids to denaturing protiens.
We had many fixed temp 37 deg units in my last bio class.
Mikebits is offline
Old 29th July 2008, 02:17 AM   (permalink)
mikebits, our professor said that it would be a eagle embryo.
kyrie2 is offline
Old 29th July 2008, 02:18 AM   (permalink)
mr.boncuk, what type of file did you send to me??
tnx
kyrie2 is offline
Old 29th July 2008, 02:23 AM   (permalink)
has anyone have the circuit diagram of incubator?? uhmm, is LM35 will be used on it??/
kyrie2 is offline
Old 29th July 2008, 02:49 AM   (permalink)
The file format boncuk used is Eagle software. I tried to convert the files to an image format for you. Let's see if this works.
Mikebits is offline
Old 29th July 2008, 02:51 AM   (permalink)
Mikebits, thank you so much ^^
your my senpai ;p
kyrie2 is offline
Old 29th July 2008, 02:57 AM   (permalink)
Actually Boncuk deserves the gratitude as he provided the circuit, I just converted the file format for you. But thanks. I had to look up senpai,
Are you in Japan?
Mikebits is offline
Old 29th July 2008, 03:00 AM   (permalink)
and also mr.bancok thank you so much for the file you send it to me
and mr. mike bits... ^^ thank you, uhmm, im here at philippines, half jap and half pinay ^^, im a new member here ^^
kyrie2 is offline
Old 29th July 2008, 03:05 AM   (permalink)
Well, Mabuhay to the forum
Mikebits is offline
Old 29th July 2008, 03:07 AM   (permalink)
^^ thank you thank you ^^,
kyrie2 is offline
Creating a remote circuit using a cell phone and circuit board kit. gluon_spin Electronic Projects Design/Ideas/Reviews 2 6th November 2007 06:44 PM
40% duty cycle square wave generator circuit.I need help to develop this circuit navinthan Electronic Projects Design/Ideas/Reviews 28 2nd November 2006 09:57 PM
electronic earth leakage circuit breaker circuit diagram jideadido General Electronics Chat 0 1st June 2004 08:50 PM
control circuit to motor circuit does it matter what wire i? troyandash Robotics Chat 2 21st May 2004 12:26 PM
Incubator Relay Circuit Plip Electronic Projects Design/Ideas/Reviews 2 26th November 2003 01:36 PM
