| Walang ano man, Your welcome for you non tagalog speakers. | |
| Hi, birds eggs need to be turned half way round a couple of times a day. Dunno why, i think it helps the development somehow. (turned around the length axis) Best of luck with it, John
__________________ ************************************************** ***************** | |
| wow, you speak tagalog?? nice walang ano man ^^ | |
turning over is easily explained. You turn over about 80 times while sleeping just for the reason, that blood flow is decellerated at spots with weigth on them. The number is mentioned in a medical report about sleeping habits of humans. Also unborn alligators and chicken need to turned over from to time. The amount of movement is of minor importance. Most important is movement at all. A hen will do only the most necessary. Hans | ||
did you not find the PCB layout in the file? BTW this circuit was done for a forum member in Africa. Unfortunately he fell victim to rebels before he could finish the circuit. Hans | ||
I did see the PCB file in the zip, was not sure how to open that one as I have only used Eagle twice now. Last edited by Mikebits; 29th July 2008 at 06:09 AM. | ||
| Ok, I think I figured this out sorta kinda. I think this is the layout file courtesy of Boncuk. Hey Boncuk, if I did not post it correctly please explain to me what I should correct, or better yet please post the correct drawing as I am still a Eagle Noob Now I have used Eagle 3 times My experience is in Mentor and Viewlogic. Thanks Last edited by Mikebits; 29th July 2008 at 07:32 AM. | |
| I use to live in the PI for 3 years. I picked up a few phrases along the way. It really served little purpose as all the locals could speak English. The only use I found was when dealing with the local merchants, that way they new I was not a tourist. They use to call me istation ditto or something like that Sa muling pagkikita ( Means see you later) | |
no problem at all. Everybody is sometimes new to some business. If you open a schematic using eagle just select "window" and from there select "board". That's it. (provided that a board was made before) Hans | ||
It's only really an issue if you use a lot of keyboard commands. I do, so I prefer to use File|Switch to board. That way, the keyboard command to switch to the board is always ALT-F-W--and when you're on the board, the command to switch to the schematic is always ALT-F-W as well. Also, if the board has not yet been created, this command asks you whether you want to create it first. With the Windows menu, the option to go to the board doesn't exist at all until the board exists, and it won't automatically ask you to create it. Torben
__________________ Curiosity was framed. Ignorance killed the cat. | ||
You must have overlooked the last sentence in my post. It said clearly that switching the window to "board" a board must exist. | ||
| Hi kyrie2, I have modified the PCB layout of the circuit and overall the size has shrunk a bit and the traces are wider. If you unzip the attached file you should get three different files as a result. The schematic, the PCB and and a suggestion how to build the incubator box. Use only as many heating elements (high current resistors) as necessary. Although the temperature will be controlled the air stream might be too hot and hitting the eggs directly they will fry instead being bred. Boncuk | |
| | (permalink) | ||
I don't mean to imply that one way is better--as I said, it all depends on who's using it. I'm just offering an alternative, which works (slightly) better for folks like me who like to stay on the keyboard. Torben
__________________ Curiosity was framed. Ignorance killed the cat. | |||
| Creating a remote circuit using a cell phone and circuit board kit. | gluon_spin | Electronic Projects Design/Ideas/Reviews | 2 | 6th November 2007 06:44 PM |
| 40% duty cycle square wave generator circuit.I need help to develop this circuit | navinthan | Electronic Projects Design/Ideas/Reviews | 28 | 2nd November 2006 09:57 PM |
| electronic earth leakage circuit breaker circuit diagram | jideadido | General Electronics Chat | 0 | 1st June 2004 08:50 PM |
| control circuit to motor circuit does it matter what wire i? | troyandash | Robotics Chat | 2 | 21st May 2004 12:26 PM |
| Incubator Relay Circuit | Plip | Electronic Projects Design/Ideas/Reviews | 2 | 26th November 2003 01:36 PM |
