Old 28th July 2008, 02:00 PM   (permalink)
Default Single ended to differential converter
Hi
I need to convert a single ended 5 volt signal (from a pc parallel port) to a 12 volt differential signal that goes to a double ended opto-coupler. Max pulse rate .5 MHz
I tried it out with a differential output shaft encoder-works great but now I need to hook it up to the 'puter.
Many thanks.
mtebob is offline
Old 28th July 2008, 02:06 PM   (permalink)
Originally Posted by mtebob View Post
Hi
Many thanks.
Look at the MAX232 ic.
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is online now
Old 30th July 2008, 08:37 AM   (permalink)
Looks like that will do the job-got some on order.
mtebob is offline
Buffer and Differential Converter justinlw Datasheet/Parts Requests 6 7th December 2007 05:45 AM
Double-ended analog to digital converter DSGarcia General Electronics Chat 1 2nd August 2007 01:36 AM
Single supply absolute value converter pikstart Electronic Projects Design/Ideas/Reviews 5 26th May 2007 01:42 PM
CAN Bus- Differential? dknguyen Micro Controllers 5 19th December 2006 12:17 AM
differential amp help krismoly Electronic Projects Design/Ideas/Reviews 11 24th November 2006 05:06 PM
