Old 26th July 2008, 03:59 PM   (permalink)
Default MR-16 Halagen yard lights to LED
I'm wanting to convert my Malibu yard lights to high powered LEDs my transformer is 12vac
Has anyone here experimented with these or know where to go and get the parts, LEDs,Drivers and Reflectors?
I have a Cree P4 LED Emitter from Deal Extreme for $5.05 Cree P4 XR-E 7090 to play around with. http://www.dealextreme.com/details.dx/sku.1302
This is the light I'm using, it will hold a MR-16 bulb http://www.solarlightstore.com/elect...espotlight.cfm
There is a great little circuit here that takes 12vac and will drive a 3watt LED and I have ordered one of these, I haven't gotten it yet http://www.dealextreme.com/details.dx/sku.13557 I think its for one 3 watts, or three 1 watt LEDs in series. My biggest question is can I put 3 one watt LEDs in series and use this driver to drive them.
The LED MR-16 bulb in the picture below has 3 - 1 watt LEDs in it and it does replace a 20 watt Halagen with no problem. It has 240 lumens and is very bright
For reference purposes, a standard 40-watt incandescent A-bulb (the familiar pear shape) puts out about 455 lumens
Thank You,
Tim
easytim is offline
Old 26th July 2008, 04:12 PM   (permalink)
3W probably won't be enough to replace a 20 halogen, I would say you need about 6W.
Screen name: Aloone_Jonez
Hero999 is offline
Old 26th July 2008, 04:22 PM   (permalink)
Default It does replace a 20 watt halagen
I bought this LED MR-16 light below and tested it, it has 3 one watt LEDS in it and it does replace a 20 watt halagen its even better than a 20 watt, maybe more like 25 watt. I was very surprise with the results. I'm using 1000 watt transformer to use my Halagen bulbs and 950 watts of that is being used up. A 3 watt LED will replace a 20 watt halagen with no problem. The cost of using my yard lights every night is $15 to $20 per month. It makes sense to me to convert to high powered LEDS. Only 3 watts of power used to replace a 20 watt halagen bulb makes alot of sense and would be worth the trouble.
For reference purposes, a standard 40-watt incandescent A-bulb (the familiar pear shape) puts out about 455 lumens.
THANKS for your input HERO 999
High powered LEDS are very new to the market, its a learning thing for all of us.
easytim is offline
Old 26th July 2008, 05:25 PM   (permalink)
The LED driver ad does not say if the input is AC or DC.
audioguru is offline
Old 26th July 2008, 06:22 PM   (permalink)
It says MR-16 that means only one thing 12vac
MR-16 is the standard light used for yard lights and operates on 12vac
Thanks for your input audioguru
easytim is offline
Old 26th July 2008, 07:23 PM   (permalink)
Is your transformer a lightweight high frequency electronic transformer or a big and heavy iron transformer?
If your LED driver is designed for 50/60Hz it might cause a problem because the diodes might not be able to switch at the >20kHz generated by the transformer.
Hero999 is offline
Old 27th July 2008, 01:27 AM   (permalink)
I'm using a big heavy duty outdoor 1000 watt iron type secondary 12vac transformer, its not an electronic type
easytim is offline
Old 27th July 2008, 11:45 AM   (permalink)
That'll be perfect.
Hero999 is offline
Old 29th July 2008, 02:00 AM   (permalink)
Default MR-16 240 lumens 3 x 1 watt LED light
I received a MR-16 240 lumens 3 x 1 watt LED light today. Its every bit as bright as a 20 watt halagen. In fact it look as bright as a 40 watt. Not bad for only 3 watts of power being used at 12vac input voltage.
easytim is offline
Old 29th July 2008, 03:23 AM   (permalink)
try HID lamps, if im correct ^^, (or is it use only for cars? i mean the hid)
kyrie2 is offline
Old 29th July 2008, 03:15 PM   (permalink)
easytim- looking at LEDBULB.BIZZ I noticed the prices were prohibitively expensive. That bulb lists for well above $250!!!!!!!!!!! I have 8 that I would need = GDP of some third world nations!!
HiTech is offline
Old 29th July 2008, 09:43 PM   (permalink)
Hey Hi Tech,
It cost $$$$$ to go Hi Tech
Take a look at this !!!!!!!! ON e-bay
High Power White LED Spot Light Bulb Lamp 12V 3W MR16 $12.00 I have two of these 1 warm 1 cool
http://cgi.ebay.com/High-Power-White...3286.m14.l1318
This one cost double $28.00, but the light is more than double than the 3w single LED above, its very bright !!!!!!!!!!!! MR16 LED CREE WHITE 3x1W(3W) AC DC 12V XR-E 240 Lumen
http://cgi.ebay.com/MR16-LED-CREE-WH...em190239759370
I'm going to use these LEDs bulbs with a 20 watt solar panel, controller and 12vdc chargeable battery for lights in my family room soon as I find a good combination and some cool looking fixtures to put them in that will accept a MR-16 bulb
This is one way to do it
MR-16 to a standard Edison Medium Base (E-26) socket adapter by
Light It Technologies.
These are made in Montana and have clips which aid in securely
holding a two-pin MR-16 floodlight in place.
PRICE: ( LIT MR-16 ) $ 10.50 each
http://www.solarseller.com/halogen_b...ase__mr_16.htm
easytim is offline
Old 31st July 2008, 04:46 AM   (permalink)
Those prices are more like it -- I'm going to look closer into this alternative choice - would be nice to lower my landscaping lighting bill as well.
HiTech is offline
lights bacole General Electronics Chat 2 9th December 2007 02:41 AM
Solar yard lights; battery options? Dialtone General Electronics Chat 11 11th September 2007 05:05 AM
LED Traffic lights RODALCO General Electronics Chat 5 11th June 2006 08:55 PM
flasher lights bishnu General Electronics Chat 2 14th February 2005 11:51 PM
pretty lights fazer General Electronics Chat 1 1st October 2002 08:13 PM
