| Hello, I'm using three transformers in a project of mine, and in that case I use the Y-D setup. (Given by the supplyer.) But whats practical diffenrence if I use the Y-Y, D-D or the D-Y setup? Why use the "industrial standard" Y-D? Johs Edit: There are the Neutral wire in the wye, And non in the Delta formation. Different uses in the States and Europe thats it? But somthine I have seen the use Star and other times Wye, same thing? Last edited by jdahl; 25th July 2008 at 08:38 AM. | |
| It is usual to use a 3 phase transformer that is Delta input and Star (Y) output. If you use a Star input, you have to use a neutral connection to the star point. If not, an unbalanced load will make the star point be at some non-zero voltage and that will give too much voltage on one or two phases. So the advantage of a Delta input is that no neutral is needed, just the three phases. If you use a Delta output, there is no zero point to connect to earth to give a neutral, so it is impossible to run single-phase loads. Even if there are no single phase loads, the voltage to ground is not known if no point of the circuit is grounded. Also, if the input voltages are unbalanced, it can cause circulating currents in a Delta secondary. | |
| A delta secondary can be good because it's easier to get higher currents with less turns which is useful at low voltages. To get over the no-neutral problem a zigzag transformer can be added to create a neutral point which can be earthed.
| Electrical Phases Basics... | Rizorama | General Electronics Chat | 7 | 15th February 2005 03:55 AM |
| Speed variator for asynchronous 3 phases motor | olivierh | Electronic Projects Design/Ideas/Reviews | 4 | 13th August 2003 04:47 PM |
