Old 24th July 2008, 01:35 AM   (permalink)
Default AVR based on water temerature
Hello,
My first post, please go easy on me...
I would like to use the resistance from a 'motor vehicles' engine temp sender, to controll a 12v source.
Guessing here...
If the resistance is 'infinity' at 0 degrees Celcius
and lets say, 10k at 82 degrees Celcius
I would like to put out say:
12v at 0 degrees Celcius
and
5v at 82 degrees Celcius
Any suggestions would be more than welcome.
Free free to correct me on the resistance of a temp sender, as I have not yet measured one.
Thank you all
Rick
rickconn is offline   Reply With Quote
Old 24th July 2008, 01:49 AM   (permalink)
what do you want to control with the voltage a motor or a lamp or ????
Robert-Jan
rjvh is offline   Reply With Quote
Old 24th July 2008, 04:23 AM   (permalink)
About the sensor
it could be a PTC or a NTC
it's a resistance based sensor with a Positive Tempature Coeficient or Negative Tempature Coeficient thats what you have to find out by measurement if you don't have any documentation of the sensor
The way you discribet it (as you said this is hypothetical) it would be a NTC the tempature goes up and the resistance come down
a resistance based sensor can't be infinity at a point as this would indicate a burn out and a permanent damage of the sensor
Robert-Jan
Old 24th July 2008, 04:26 AM   (permalink)
Do you need to vary the 12V source in a linear fashion?
Or
Just only to detect two temperatures & control the output?
If it is 0C --->then out 12V
If it is 85C --->then out 5V
Gayan
My Website
http://gsmicro.blogspot.com/
Gayan Soyza is offline   Reply With Quote
Old 24th July 2008, 05:03 AM   (permalink)
Good afternoon,
Wow, I wasnt expecting so quick replies..
Thank you all...
Gayan
Yes I would like the voltage to be linear between 5 to 12v.
I was hoping that as the tempreture was rising, the voltage was dropping.
Between say:
If it is 5C --->then out 12V
So I will guess at 45 degrees I would be getting 8.5 volts.
rjvh
PTC or a NTC
I do not know what is 'common' on a temperature sender from a vehicle, but Im hoping to use something 'generic'.
If anyone can enlighten to on the 'automobile' temp senders, that would solve that question...
Part 2:
Its controlling a filiment.
Thank you both for quick replies...
I best check back more often.
Old 24th July 2008, 05:12 AM   (permalink)
Thermistors are not very linear.
Mikebits is online now   Reply With Quote
Old 24th July 2008, 06:21 AM   (permalink)
what is a filiment ??
I can't picture what for device that is
how much power does it consume?
Robert-Jan
Old 24th July 2008, 06:40 AM   (permalink)
Robert-Jan
I would like to have the element consume a maximum of 15 amps.
Its like 2 platess in a battery, but as the element heats the water, the current drain is increasing, so as the temp rises, I thought to reduce the voltage to it.
Cheers
Rick
Edit: The resistance between the plates is approw 1mg.
Old 24th July 2008, 07:04 AM   (permalink)
Cheers
Rick
now I have even more questions
I think your filiment is a heating element or not ??
if it is controling the temp of a amount of water than i would suggest that you make something with a PWM control (puls with modulating control)
the efficiency is much better than when you just lower the voltage
resistance is messured in Ω and the oposite (conduction is in siemens)
i am not familiar with mg
Robert-Jan
Old 24th July 2008, 07:23 AM   (permalink)
Robert-Jan
Thanks Rob and Jan
No its not.
It is 2 plates, like in a battery, making contact via an electrolytic.
The resistance accross the electrolytic is at room temp, approx 1 megaohm
Using a 12vdc supply, its consuming around 5 amps
Because of the potenial difference between the plates, the electrolytic heats up. As it does, the current draw increases uncontollably till the electrolytic boils.
I have found that reducing the voltage manually to 5v, seems to limit the current drain to a maximum of 15amps, which would be as much as I could tolerate.
Really, Im seeking a simple feedback circuit to limit the voltage/current based on the temperature of the electrolytic.
Cheers
Rick
Old 24th July 2008, 07:34 AM   (permalink)
Now i do get the picture
never thougt about a current control with a steady voltage? (battery charger)
by the way it's one person Robert-Jan (I am not offended)
Robert-Jan
Old 24th July 2008, 07:50 AM   (permalink)
Robert-Jan
Evening,
I dont have a preference for regulating current, or voltage.
I thought that a temp sender, from a car, could be used to regulate, either current or volatage.
However, a simple schemetic, would help...
Im guessing, the sender will have a varying resistance between to 'knowns'
Some sort of voltage divder, accross the base of a tranistor, to regulate between the emitter and collector, either voltage or current.
I will have to hunts the values on the sensors, probably, to be fair to everyone.
Kind regards,
Rick
After reading a couple of forume, I think it would be safe to say, a car temp sensor may be closte to:
5000 ohms at 0 degrees C
and
200 ohms at 100 degrees C
Hope this helps
Regards
Rick
Old 24th July 2008, 08:41 AM   (permalink)
Hi I still have to wait a few hours when it starts to be evening here
i made a small sketch that works with a FET as a variable resistor so controling the curent
as the sensor value is not known you have to experiment with the values depending on what you want
the resistor values should be preferible in the kΩ lower is not recomended
the FET have to be a type that can handle the 15Amp as you required and i would defenetly cool this component as it will be hot when it has to handle that amount of current
Robert-Jan
Old 24th July 2008, 09:23 PM   (permalink)
Robert-Jan
Robert-Jan,
Thankyou for your sketch,
I will have a peek overr the next week or so.
I will let ou know how I go.
Again, thank you kindly
Rick
automobile, avr, temperature
water sensor? silvarblade Electronic Projects Design/Ideas/Reviews 10 7th October 2007 05:32 PM
Ok, let's burn sea water... philba Alternative Energy 16 18th September 2007 11:01 AM
Temerature sensor JPI General Electronics Chat 3 21st November 2006 01:48 PM
does water destroy ic`s? Charon102 General Electronics Chat 12 2nd November 2004 02:26 PM
Water Electrolizer Lann Electronic Projects Design/Ideas/Reviews 8 24th September 2003 03:15 PM
