Old 22nd July 2008, 08:24 AM   (permalink)
Default Dual polarity power supply
Hi
I am looking to build a dual polarity power supply for prototyping my projects. I am looking at
a variable output voltage of +/- 0 to 40V DC, max current drawn 5A DC. Does anyone know any circuits that can do this ? I was searching for RC4194 based designs and LM317 / LM337 based designs. Any suggestions ?
olcal is offline
Old 22nd July 2008, 08:39 AM   (permalink)
Originally Posted by olcal View Post
Hi
The RC4194 dual tracking psu ic, is a bit dated, circa 1977.
May I ask why you require a -40V psu at 5Amp.?
EDITED: added a pdf
This pdf shows some applications for the RC4194
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is online now
Old 22nd July 2008, 09:06 AM   (permalink)
I was searching for RC4194 based designs and LM317/LM337 based designs. Any suggestions ?
Another choice would be the LM350T. It's a drop-in replacement for the LM317, but does 3A instead of 1.5A. (And Eric may be right, 5A for the negative supply is likely much more than you would ever need.)
To get the LM350/LM337 to 0V, however, you have to muck with them a bit. Without adding some opposite polarity biasing in the adjustment legs, they both start out at about 1.2V. And you'd have to add some circuitry to make them track, if so desired. There may be some good single-chip tracking regulators out there, but none are coming to mind.
EDIT: I forgot the LM338K: another replacement for the LM317, but does 5A.
Corey
Rapp's Law of Inanimate Reproduction:
"If you take something apart and put it back together enough times, you'll eventually have two of them."
saturn1bguy is offline
Old 22nd July 2008, 10:10 AM   (permalink)
Ericgibbs, a number of the circuits that I want to prototype ( most of them are audio power amps, though not all) require supplies dual polarity supplies +/- 35Vdc at 2A. I gave upper limit of 5A. They are all discrete transistor based designs from Phillips design audio amplifier design book. Do you forsee any problems with the power supply ?
olcal is offline
Old 22nd July 2008, 10:37 AM   (permalink)
If you look at the pdf I posted, it shows a high current dual tracking power supply circuit.
Dont exceed the input voltage rating of the RC4194.
Eric
PIC tutorials:
Old 22nd July 2008, 04:33 PM   (permalink)
Be warned that +/-40V is 80V which is verging on hazardous voltages.
Screen name: Aloone_Jonez
Hero999 is offline
Old 23rd July 2008, 04:41 AM   (permalink)
Probably your most difficult requirement is the 0V minimum. Your monolithic regulators tend to have a reference around 1.2V. And, at 5A, at any low voltage, the pass elements must dissipate 5A*(Vunreg - Vout).
A much easier design would be +/-20 to 40V @ 5A. (With option for voltages below 20V at reduced current.)
From a practical sense, do you really need a regulated supply? You may find that a +/-40V unregulated (simple bridge on a 56VCT transformer), supplied by a 500VA variac would suffice. It would be a lot cheaper.
mneary is offline
Old 23rd July 2008, 04:56 AM   (permalink)
Right, I mentioned this above.
This is a great point. But, it's still do-able if one really wants it. Many commercial power supplies use relays to switch to lower voltage secondary taps...
Corey
Old 23rd July 2008, 07:52 AM   (permalink)
The RC4194 can go down to 50mV Vout.
I wouldn't recommend using for a new project, because of the availability.
It was a 'nice' device, especially the dual tracking feature.
Eric
PIC tutorials:
dual polarity power supply Wond3rboy General Electronics Chat 18 30th July 2008 04:45 PM
Dual Power Supply Microcontroller meles Micro Controllers 1 10th April 2006 05:37 PM
Constant Current, Auto off, and Switch polarity power supply ljm Electronic Projects Design/Ideas/Reviews 0 5th April 2004 04:54 AM
dual power supply Erwin_Macaraig Electronic Projects Design/Ideas/Reviews 2 3rd April 2004 02:54 AM
dual power supply.... mugzzzzy Electronic Projects Design/Ideas/Reviews 2 17th February 2004 07:55 AM
