Old 18th July 2008, 01:29 PM   (permalink)
Default charge NiMH 3.6 350 mA battery
Hello I want to charge a NiMH 3.6 350 mA battery and I want to find a circuit 220 V (AC) to charge the battery
oslinux23@yahoo.gr is offline
Old 18th July 2008, 03:09 PM   (permalink)
A company called Linear Technology (linear.com) do a range of off-the-shelf charger IC's - most NiMH charger ICs only require a couple of extra components and could easily be bodged into an existing wall-wart type power supply enclosure.
Please note that I dont think you will find (an IC) one with 220VAC input and charger output ;-)
There are some good app note on the Maxim website about battery charging as well.
Good luck with it!
S.
advert removed by moderator.
ste5442 is offline
Old 18th July 2008, 04:19 PM   (permalink)
Wall wart to convert it down to somewhere around 7-9 volts then an LM317 running in current limiting mode to provide a 35ma constant current charge.
picbits is offline
Old 18th July 2008, 07:09 PM   (permalink)
Energizer and other battery manufacturers recommend using a trickle charge current no more than C/40 which is only 8.75mA for this tiny battery.
You need a battery charger IC to detect when the battery is fully charged then swith off the chearger or switch to a low trickle charge current.
The battery charger IC will be able to charge quicker than all night long.
audioguru is offline
Old 18th July 2008, 07:18 PM   (permalink)
Just get a cheap nokia phone charger, put 2 of the batteries you want to charge in series and your'e done. The charging current might be a bit high, but I've used it many times (and if your'e not worried that you will not get a 1000 recharges from it). Just note it will not stop charging when the batteries are full.
Do not play around with 220V.
Boomslang is offline
Old 19th July 2008, 05:29 AM   (permalink)
A Ni-MH battery charger knows when the battery is full and turns off the charging.
A Nokia power supply is made to feed the lithium charger circuit in a cell phone and will overcharge a Ni-MH battery.
Old 19th July 2008, 07:14 AM   (permalink)
I should have added: OLD Nokia charger from a second hand shop. IE: 5110 charger. Sorry. As far as I can tell it does not stop charging when the battery is full... never tested it.
Old 20th July 2008, 01:23 PM   (permalink)
Most of the newer phones I have dealt with power a charger IC which is inside the phone.
Do the older phone power supplies have a charger IC built in?
ste5442 is offline
Old 20th July 2008, 02:06 PM   (permalink)
We should be talking about apower supply for a phone, not a charger.
If you want to charge a battery properly then you need a power supply and a charger circuit.
OK to trickle charge NIMH at 50mA? Revolvr General Electronics Chat 14 18th March 2007 10:10 PM
Can I trickle charge a NiMH (4xAA @ 2300 mAh) with 1ma? William At MyBlueRoom General Electronics Chat 2 21st March 2006 03:20 AM
How do ye charge NiMH batteries Thunderchild General Electronics Chat 2 17th July 2005 08:24 PM
How do ye charge NiMH batteries Thunderchild General Electronics Chat 1 17th July 2005 11:13 AM
Whats the simplest way to charge NiMH batteries ? pkshima General Electronics Chat 15 5th May 2005 05:48 AM
