| This is my schematic that i am using to drive a bipolar stepper motor. The thing is i want to know what wrong with it? Here is the connection:Electronic Circuits Projects Diagrams Free - uaefame's Album: Circuits - Picture Q1> Do i need to connect a 10k resistor between the 16F84a and sn754410 pins 2,7,9 and 15 or leave it as it is? Q2> I am using same power source for Vcc1 and Vcc2 does it matter because the pic need 5V and the stepper need 5V same volt why get a new power source? Q3> The motor behavior is strange going back and forth, its strange if you spot any mistake in the schematic let me know? Thanks in advance
__________________ Hesham Ismail Mohammed Sharif Thank me if you want | |
| Try adding more DC filtering around VCC2. | |
| What does that suppose to do dc filtering? Do you mean i add capacitor or something?
| Yeah, caps. I would add a 10uf cap right at the reg output. I would also put a .01 cap near the PIC power pin. And caps around the VCC1 and 2 pins. DC supply noise causes erratic behavior. It is just good practice to use good DC filtering. | |
| This link looks useful. Interface to a motor controller | |
| Do you mean i connect between VCC2 and ground a capacitor of 10 or 0.01uF. Same goes to the VCC1 and ground another 0.01 or `10 uF. Q1> Is this the proper way to connect them? At the output of the voltage regulator and pic power supply there are alreay capacitor there. I already did this but nothing work still same problem? Did i understand dc filtering wrong? Thanks in advance
__________________ Hesham Ismail Mohammed Sharif Thank me if you want Last edited by uaefame; 12th July 2008 at 05:59 PM. | |
| I just noticed something, why are you not connecting the enable pins. They should not be floating. | |
| Yes, enable pins need to be tied to VCC1 via a 10k resistor. You also don't seem to be implementing any current limiting - If you use a higher voltage than the motor's rated voltage (About 10x higher max !) and limit the current to the rated current for the motor you will get much more torque. The only reason my stepper motors oscillate around the same point are because I've reached the torque limit. Remember that as speed goes up, torque goes down for a stepper motor. You might also want to think about adding some protection diodes to the outputs, depending on the size of your motor. (The driver already has some.) Last edited by yngndrw; 12th July 2008 at 08:34 PM. | |
| Here is my additions to the previous circuit after taking into consideration yngdrw and mikebits suggestions. Still the motor osicilates in the same place. The only thing i didn't add until now is diodes as mentioined yngdrw and in sn754410 there are internal diodes but adding more diodes will not hurt for the time being i will stick without diode. Here is my Electronic Circuits Projects Diagrams Free - uaefame's Album: Circuits - Picture Sorry for my poor knowledge in electrical but with ur helps, I can one day help as may as i can maybe to you guys as well because i have strong (solid) knowlege in other fields. Any suggestion is welcomed and will be looked into it. Thanks in advance
__________________ Hesham Ismail Mohammed Sharif Thank me if you want Last edited by uaefame; 12th July 2008 at 09:22 PM. Reason: Grammer | |
| You only need one resisotr for the enable pins. Tie both enable pins together then use a single 10k resistor to VCC1. Double check that the motor coils are connected as you expect them to be. Post the code that you're using on your PIC, maybe that is wrong ? Do you have any load on the motor ? | |
| Perhaps your stepper needs more current than your regulator can supply. Have you measured your supply voltages? Maybe as a test, you can run VCC2 from seperate supply. | |
| Thanks yngndrw, 1) I removed the extra resistor 10K and i connected it as you told me hereElectronic Circuits Projects Diagrams Free - uaefame's Album: Circuits - Picture 2)The motor coil is fine i double check it again and again 3)The codes are here Code: LIST P=PIC16F84A #INCLUDE "P16F84A.INC" __CONFIG _CP_OFF & _WDT_OFF & _PWRTE_ON & _XT_OSC errorlevel -302 cblock 0x0c d1,d2,d3 endc org 0 init banksel TRISA ;bank 1 clrf TRISA clrf TRISB banksel PORTB ;bank 0 clrf PORTB main movlw b'00000001' movwf PORTB call Delay8ofsec movlw b'00000100' movwf PORTB call Delay8ofsec movlw b'00000010' movwf PORTB call Delay8ofsec movlw b'00001000' movwf PORTB goto main Delay8ofsec ;124993 cycles movlw 0xA6 movwf d1 movlw 0x62 movwf d2 Delay8ofsec_0 decfsz d1, f goto $+2 decfsz d2, f goto Delay8ofsec_0 ;3 cycles goto $+1 nop ;4 cycles (including call) return end I wish these information can help you figure what wrong Thanks in advance
| Ah, you only have one coil energised at a time. Because of the driver IC and that fact that the enable pins are not used, this means that the second coil acts as a break. Try: 00000101 00000110 00001010 00001001 I think that's the reason anyway. Last edited by yngndrw; 12th July 2008 at 10:33 PM. | |
| Hello yngndrw, I did as you said but the problem still the same moving back and forth Here are the updated codes Code: LIST P=PIC16F84A #INCLUDE "P16F84A.INC" __CONFIG _CP_OFF & _WDT_OFF & _PWRTE_ON & _XT_OSC errorlevel -302 cblock 0x0c d1,d2,d3 endc org 0 init banksel TRISA ;bank 1 clrf TRISA clrf TRISB banksel PORTB ;bank 0 clrf PORTB main movlw b'00000101' movwf PORTB call Delay8ofsec movlw b'00000110' movwf PORTB call Delay8ofsec movlw b'00001010' movwf PORTB call Delay8ofsec movlw b'00001001' movwf PORTB goto main Delay8ofsec ;124993 cycles movlw 0xA6 movwf d1 movlw 0x62 movwf d2 Delay8ofsec_0 decfsz d1, f goto $+2 decfsz d2, f goto Delay8ofsec_0 ;3 cycles goto $+1 nop ;4 cycles (including call) return end
| Maybe I got the order wrong, try: 00000101 00000110 00001001 00001010 (Swapped the last two lines.) How long is the delay ? (I'm not an asm person...) Try using a very slow delay if you're using a fast one - It may be too fast. (0.5 seconds, etc.) You could also make it only step on when a button is pressed - Then you can check all of the outputs with a multimeter. Last edited by yngndrw; 12th July 2008 at 11:01 PM. | |
| stepper motor or Torque motor | yagtoby | Electronic Projects Design/Ideas/Reviews | 1 | 14th June 2008 05:29 PM |
| Stepper Motor Vs DC Motor for wheels | AceOfHearts | Robotics Chat | 5 | 25th May 2008 04:16 PM |
| stepper motor | mayassn | Electronic Projects Design/Ideas/Reviews | 2 | 9th April 2008 09:21 PM |
| Stepper Motor | watzmann | Robotics Chat | 20 | 9th April 2005 08:49 AM |
| stepper motor | jim bro | Electronic Projects Design/Ideas/Reviews | 0 | 26th May 2003 09:54 PM |
