Old 26th October 2003, 05:31 PM   #1
Default Artificial horizon indicator for RC airplanes
Recently I saw an Electronic Flight Information System (EFIS) for full size aircraft which uses a Compac iPac for its display-including the AHI. I would like to attempt creating just the AI which -I think- is reading two axis, pitch and roll. The Futaba PA1, or 2, autopilot senses movement about these axis and sends a signal to the aileron or elevator to correct to level flight. If you took these 2 signals and sent them to..........? Could this be turned into such an instrument. Why? to observe movement when flying with a video TX. With my GPS and Video Display Overlay, I get airspeed. lat/lon, altitude, and direction. Any thoughts? Thanks. Bill
Technowanabee is offline
Old 27th October 2003, 02:46 AM   #2
Check out these Dual Axis Accelerometers from analog devices.They are very small(5mmx5mm) and relatively cheap.They can accurately measure static acceleration on two axes(pitch and roll).
With analog ouptut:
http://www.analog.com/Analog_Root/pr...DXL203,00.html
with PWM output:
http://www.analog.com/Analog_Root/pr...DXL202,00.html
Eclipsed is offline
Old 27th October 2003, 03:03 AM   #3
Check this out also...
http://www.electro-tech-online.com/v...033&highlight=
Eclipsed is offline
