| Today I will brainstorm some more and see what rough ideas I can come up with. However, I have a feeling that I am trying to simplify something that is inherently complex (or more complex than I would like). If that is the case then hey what the hell, maybe I will try the complex and see if I can learn from it | |
I read the circuit description they gave and looked at the schematic but I do not understand how that circuit works. They say in the description that the phase changes when person moves... but isn't it the frequency that changes? Even when there is no person in the way, the signal that is reflected of the wall will be out of phase from the original signal. Wouldn't this cause a false trigger? Or is this circuit assuming that there is no wall for the signal to get reflected back to the receiver when there is no person in the way? If you guys could take a look at this circuit and give me your thoughts, I would greatly appreciate it. | ||
| On kit20 I would replace the 741's with something a little less lousy like the TL072. I would also consider replacing T3 with a JFET, and change the bias accordingly (much higher impedance input, maybe 10Meg/3Meg.) I would also put a 100n capacitor across the power input as well as another across the op amp supply pins. And I would move the op amp bias point to the center of their common mode range instead of Vcc/2 (the two 10k resistors.) I also haven't found how kit20 distinguishes phase. It looks like an amplitude detector to me (senses changes in amplitude). The 4.7u capacitor in parallel with 10k is the low pass filter similar to the other circuits, and the 100n in series with 100k is the high pass filter. They've included an envelope detector in place of a Schmitt trigger. U3 is a crude but effective latch. Note that the kit20 schematic doesn't include a transmitter, I guess you just borrow the one from kit49. | |
http://web-ee.com/images/UltrasonicMotionDetector.pdf Basically it tracks the derivative of the envelope of the incoming signal. If it's too large, it sets off the alarm. This means that initially you'll get a false reading when you power up the unit, but it's also able to adapt itself to whatever environment (i.e. reflections) it's in. | ||
| Thank you for that link pc88. Yeah, it seems like this project is a bit much for me. I mean, I can probably build it and have it work but all I will be doing is reading someone else's schematic and just making the circuit. Hardly learning if at all. I guess I am going to have to go with the PIR or IR solution. I will create another thread to start developing a new circuit. Thank you all for your help. I have learned a tremendous amount of information that I otherwise probably would not have come across for quite some time. | |
| You can do it. Take it step by step. | |
| ei guys please help in searching any simple alarm circuit..... i need it for our project in our shop in school..... im a electronics engg. tech. student... will some can help me???.... | |
| Have you read through this thread from the beginning? What questions do you have? | |
| I still havent gotten around to making the PIR sensor alarm (or the thread for that matter). Been way too busy but now I think I will have so more time and might start looking into it again. So standby for more questions | |
| Transducer Question | lclark | Datasheet/Parts Requests | 11 | 14th June 2008 12:34 PM |
| Ultrasonic Transducer | rcd316 | Datasheet/Parts Requests | 6 | 1st April 2007 04:53 PM |
| Ultrasonic Transducer/Reciever | bryan1 | Electronic Projects Design/Ideas/Reviews | 7 | 7th September 2005 03:43 AM |
| Pic driving ultrasonic transducer | mlt57sooner | Micro Controllers | 1 | 22nd April 2005 09:42 AM |
| Need datasheet for an Ultrasonic Transducer | mammanoti | Datasheet/Parts Requests | 0 | 31st March 2003 10:29 PM |
